Stewart Report post Posted November 6, 2012 The collar is wating to be fitted and yes it is off center. was not paying attention. The other two are pipe stands and could be used as belt holder if i more snap was used. Thanks for lookiing. Joe Quote Share this post Link to post Share on other sites
Mijo Report post Posted November 8, 2012 +80 views and no posted comments, huh? Maybe it's the picture but the stamping on the collar doesn't look as clean as the stamping on the pipe stands. Aside from stamping names and phone numbers on leather dog tags I don't do any stamping at all, so my comment has little experience behind it. Quote Share this post Link to post Share on other sites
Stewart Report post Posted November 8, 2012 Mijo, You may be correct on the picture and correct on the stamping. I was using the table i was sitting at on the collar and a different table that i had been using for a few years. Different heights and i think it changed my technique on stamping. Its like starting over. I am use to no responces. . Joe Quote Share this post Link to post Share on other sites
David8386 Report post Posted November 8, 2012 Joe, I think you are right on changing tables affecting your stamping. I have noticed differences in mine when I tried to change hands. Are you using the table you made on the porch now? It could also be the lighting differences out there also. Like the dog collar. David Quote Share this post Link to post Share on other sites
Stewart Report post Posted November 8, 2012 David, The lighting is a problem also. Sun shawdows. put a lamp on the table. Yeap, dumb time of year to use it but if I dont I would have a lot of splaning to do. Thanks on the collar. That is also a learning experience. If there is a next time a buckle with a bar in the middle instead of type used on this > regular belt buckle. Joe. Quote Share this post Link to post Share on other sites
