I'm getting ready to pull the trigger on a new machine, one I'm going to use mostly for leather upholstry work. I was hoping one of the experts might let me know what machine they thought was the best for my work. The Consew I can get new for 1250.00 or so, the Juki for around 1850.00.
Thanks,
Steve
Im far from an expert, but from your bio you seem to specialize in holsters. I just bought a Techsew 4100 and am very pleased with it for sewing heavy leather projects like holsters. In order for folks to help you you need to be a little more specific of the Juki and consew you are looking at.
Old Guy that can't see too well anymore.
A Consew 206RB(-5), or Juki DNU-1541, or LU-1508 (for heavier materials) are all top of the line upholstery machines. All are able to sew leather, up to a maximum of 3/8 inch, with #138 to #207 thread. They use the commonly available system 135x16 leather point, and 135x17 round point needles. These needles are available in sizes up to a #25. The Consew has a large M style bobbin, while the Jukis have a larger double capacity hook and bobbin.
Posted IMHO, by Wiz
  On 2/8/2013 at 11:09 PM, LeatherWerks said:
I'm getting ready to pull the trigger on a new machine, one I'm going to use mostly for leather upholstry work. ...
Thanks,
Steve
Where is there anything mentioned about wanting to use it to sew holsters?
Edited by Wizcrafts
Posted IMHO, by Wiz
The only holsters you can sew on a Juki, Consew, Chandler, or Singer walking foot flat bed upholstery grade machine are pancake holsters. You will be limited to a maximum size 207 thread. The large M or DNU/LU bobbin machines can hold enough #207 thread to do plenty of holsters. You machine will be pounding hard with #207 thread, a #24 needle and lots of foot pressure.
For leather standard upholstery, use #138 thread, with a #22 or #23 leather point needle. If this is too large, go down to #92 thread, with a #19 or #20 needle.
Posted IMHO, by Wiz
In his Bio it says his specialty is holsters.
Art
Okay, I guess I should have given more info than I did. I have a Cobra class 4 that I bought from Steve T. That's what I use to sew belts, holsters and thick stuff. The problem I have is that I'm trying to do some upholstery work and other items that use less than #207 thread. Getting the tension right on a Cobra 4 using 69 or 138 thread is a feat that Art and the Wiz should only undertake. Hence the need for a new machine, or at least the justification for that need to my wife.
The Juki sounds like a small step up from the Consew 206RB-5 but it's also $600.00 more. The prices I'm quoting here are from a dealer in my state. I'm trying to avoid $300 in shipping charges. When I bought the Cobra 4, I purchased it at the Wikenburg, AZ trade show and brought it home in, believe it or not, the back of a Toyota Prius, fully assembled.
I don't feel like I made a bad decision on the Cobra 4, and that decision was based on recomendations here on this forum. Since this is a new machine type for me, I was hoping to rely on the expertise again.
Thanks,
Steve
I'm following this post a bit now (I'm looking around for a machine myself): The Cobra class 4 should be able to use threads all the way from 69 to 415. Why is it that you have difficulties doing the thinner threads? Is it a Cobra problem only?
Lucas
Edited by bikemaniac
Lucus for me, using #69 thread is not so much a problem, the Cobra 4 will do it, but I have always found it difficult to get the bobbin tension tight enough. It can be done, but then if you need to go back to #277, it's a process to get the tension correct again. So, the Cobra 4 will sew using all the thread sizes you mentioned, I'm just not a fan of making adjustments everytime I change projects, i'e., holsters to billfolds.
Steve
I have a 206RB along with the cowboy 4500. They seem to complement each other well. I don't use the 206 too often but its nice to have when I do. I've been considering selling it and getting the Cowboy 227r as I think I could get a little more use out of it for lighter weight stuff and I could get a flat bed attachment for when I do need a flatbed.i have a little while to think about it while Bob is waiting on more to come in. For upholstery work though the 206rb would certainly be a good choice and is a solid machine. I have no experience with the Juki but I'm sure its great as well.
