Members Oak Grove Leather Works Posted February 20, 2013 Author Members Report Posted February 20, 2013 Thanks for all the advice. It will certainly steepen the learning curve for me. I made a headstall and you can see my work improve from ring to ring. I'm going to have to replace most of it with better stitching, but it could be worse. It could be raining. Quote
Cobra Steve Posted February 27, 2013 Report Posted February 27, 2013 Hi folks. This is for anyone who owns a 441 clone type of machine. When using the slotted plate, holster plate, or the stirrup plate, you have to remove the feed dog, add stitch length, and in some caes increase the foot pressure. When sewing without a feed dog you have taken away half of the feeding and to compensate for this you must increase the stitch length until you achieve the desired look. Thanks, Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
Members art23 Posted November 8, 2013 Members Report Posted November 8, 2013 Hi Steve . Are there any repercussions if you use the slotted plate, holster plate, and the stirrup plate and you do not remove the feed dog. Is there any type of damage that can occur? Quote
CowboyBob Posted November 8, 2013 Report Posted November 8, 2013 If you leave the feed dog in when trying to use these needle plates it will hit the bottom of the plate & either break some major part or just bind up the machine. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members BigJake Posted November 8, 2013 Members Report Posted November 8, 2013 I have a C4 machine and this is what I've learned and some of this may be of benefit to the OP. The text in blue is from another post which I describe some of the problem. I have the same problem with my C4 machine and it's about the top thread tension. Put about 1/4" of leather in your machine and turn the handwheel very slowly and look closely at the needle/presser foor interaction. You might take off the dust cover off and also watch the thread as the stitch is picked up. When the hook picks up the thread the needle is on the way up and as the hook rotates on around pulling thread through the needle and top thread tensions, observe what happens. The top thread is pulled toward the front of the machine and at the same time the needle is pulled/bent toward the front of the machine along with your product because the needle is still in the product. The high tension will cause the product to slip under the pressor foot, which is effect shortens the stitch length. The thicker the material being sewed, the more top tension, therefore shorter stitches. I also expect that when you are backstitching the needle is not going in the same hole. That's because to compensate for the above issue if you want 6 STI you will need to set the machine for 5 STI. When the lever is reversed there is no p[roduct slipage under the presser foot and therefore you will get 5 STI on the backstitch. Take a scrap piece of 8oz veg tan and stitch without any thread in the needle. The stitches will be longer than when thread is used. Is there a fix for this, which I'm sure is a top tension issue? I don't know. I do believe that haveing the front of the walking foot or needle foot cut out adds to the problem. When I sew 1/4" of veg tan using 277 thread top and bottom and a 25 needle, the needle will be bent forward completely into the cutout. The other heavy stitchers like the Ferdco and Juki 441 I've seen, don't have this cutout. Just a round hole for the needle to pass through. This round hole would prevent the needle from coming forward nearly as much and I believe would solve much of the problem. This is follow up info I've learned since then. I basically sew cowboy gunleather using veg tan leather in 9/10 to 12/14 oz and 277 nylon thread top and bottom and a 25 needle. I mainly use the holster plate and the feed dog with the teeth on it, (don't know what it's called). This feed dog has a smnall round hole for the needle to pass thru and the small hole is the reason I use it. I know the manual says to remove the feed dog when using the holster plate, but on my machine the feed dog does not hit the plate at any time. Without the feed dog the thread and the needle will be pulled forward just as the needle is about to clear the leather and the shuttle hook has picked up the top thread and is pulling the thread forward along with the leather,the stitch length is shortened due to the material moving forward under the pressor foot. This also causes the stitches not to match when reversing the stitch. Having three different type of needles and all have the same issue which is the needle below the scarf is back to normal diameter but with no slot to recess the thread the top tension is thrown off by this increased tension as the needle is about to clear the leather. Having the feed dog with the small round hole forces the thread to be pulled in a more straight down pull and does not pull the needle forward or the leather and therefore the problem. Increasing the pressor foot tension to the max did not fix this problem. Only adding the feed dog. This issue is very difficult to explain in text and I hope this explanation is clear. Turn your machine over by hand very slowly and carefully watch the leather, the needle and pressor foot and interact, if you have this problem, you should consider what I've tried to explain above. Quote
Members BigJake Posted November 8, 2013 Members Report Posted November 8, 2013 My previous post need correcting. The OP was about STRAP PLATE and somehow I got HOLSTER PLATE and my comments were pertaining to the HOLSTER PLATE. The strap plate is not as tall and I'm certain the feed dog would hit the plate. Sorry for the confusion. Quote
