Let me know what you think,Construction criticism appreciated.Only my 2nd project
post-36351-0-47034000-1360992063_thumb.j
post-36351-0-44412600-1360992077_thumb.j
post-36351-0-22097000-1360992091_thumb.j
I think its good for a second project. I only have made one wallet sp far, but I think I can give you two hints. First is to watch the force you apply when sewing thin leathers. If you pull the thread to tight you make the leather wrinkle in that area. Picture quality is not so good but I think this happened at the third pic lower left corne of the wallet. Second hint is to use a small hole punch at the end of the credit card slots. It looks like you have made a vertical cut at the ends of the credit card slots. This could rip or become loose over time which is not so likely with a hole. A hole looks more elegant too (personal oppinion).
Keep on going. You will become better every time
Jonathan
Yes you're right i did cause some wrinkling in a few places, and i'll try the hole punch on the next one.
There is so much to learn on here from some amazing artists
Take some time and look through the site, galleries, technique threads
Keep plugging away at it!
