Members billymac814 Posted February 21, 2013 Members Report Posted February 21, 2013 Here's my center foot. I did it with a small cut off wheel and then just polished it up. Its much easier to see where the needle is going to go. I don't have the table attachment mounted when doing holsters or belts. I don't use it for much actually unless its something that's really big. What does the flatbed have to do with the feed dogs though? I don't use the holster plate very often at all either. I'm pretty sure I'm going to just put my feed dogs back in, I seem where another guy was able to grind enough material out of the bottom of the holster plate for the feed dogs to clear so they can be left in place. I was much happier with how it worked with them in. I'm going to give it a few more days and see how it goes. Quote www.mccabescustomleather.com
Tree Reaper Posted February 21, 2013 Report Posted February 21, 2013 If the holster is off the table you have more clearance and can use the standard plate with the dog. With the table on the holster is sitting on a slant due to the thickness of the holster. Quote
Members billymac814 Posted February 21, 2013 Members Report Posted February 21, 2013 Oh ok, I see what you mean now, I wasn't sure what you meant at first. I find it easier to use without the table with most items, its easier to maneuver things around. I don't need the holster plate very often so I think I'm just putting my dogs back in. I think with the smooth feed dogs that the marking is minimal and I've had better results with it feeding and back stitching. It could possibly be me since others seem to use the slotted needle plate and like it I just am not seeing the advantage. The feed dogs are so large that its almost like having a smooth plate that moves with the work. I almost prefer the look of the back side with the dogs in as they basically flatten the stitches down for me, with the slotted plate it makes it look different but I wouldn't say better. Quote www.mccabescustomleather.com
Members Les No6 Posted February 24, 2013 Members Report Posted February 24, 2013 In essence the unison feed mechanism is an elaborate needle feed jump foot where the lower and upper needle guides are brought into contact with the item being sewn thus compressing the material while the stitch is being formed (not needed on leather) and binging the needle fixing points (needle guides) into the closest possible proximity to give the needle the greatest possible rigidity in the direction of feed. You should really be using a bottom needle guide with a slotted plate it’s an important component, the feed dog is a through plate needle guide, under plate needle guides are the same but are flat on the top you can grind down the former if you can’t find an under plate one (Ferdco used to sell them). With a slotted plate you now have needle feed jump foot and the upper needle guide (middle foot) should be removed, most needle feed jump foot machines don’t even have them such as the Juki 421 (441 without middle foot) the problem (when using slotted plates) with the upper needle guides on unison feed is that it presses down on the leather when feeding, pushing it into contact with the plate whereas with needle feed jump foot the upper needle guide doesn’t come in contact with the leather and prior to the needle feeding the needle lifts the leather a little clear of the plate giving complete freedom for the needle to feed. Under plate needle guides are adjusted so that the front of the needle is in contact with the front of the needle guide as the needle feeds, the needle is now fixed at the needle bar and at the bottom (and supported somewhere between by the upper needle guide if used) and is now ridged in the direction of feed, the guide needs readjusting when you change the size of needle. In summary the lower needle guide is an essential component irrespective of plate used upper needle guides are expendable in most cases and are only needed when using fine needles for extra support, cutting the front out of the middle foot renders it useless as a needle guide, if you are unhappy with the middle foot just remove it now you have a needle feed jump foot (421 the model intended for leather) irrespective of throat plate used and regular feet can now be used for the jump foot. As you have probably realised by the time you’ve read this far the problems you are experiencing when using slotted plates are due to the needle flexing because it’s not properly supported. Quote
Members billymac814 Posted February 24, 2013 Members Report Posted February 24, 2013 I think I'm just putting my feed dogs back in. That sounds simpler and I was perfectly happy with how it stitched with them. It makes sense that needle flexing could be causing feeding issues, I can't say for sure if that's my problem or not. I'm not actually having problems per se but I just liked the way it worked better with the smooth feed dogs installed. I get what your saying about opening up the middle foot being useless as a needle guide but its easier to see and that's how the middle feet come with the Cobra machines and I haven't heard any problems arise because of them. Quote www.mccabescustomleather.com
Members Les No6 Posted February 24, 2013 Members Report Posted February 24, 2013 I think I'm just putting my feed dogs back in. That sounds simpler and I was perfectly happy with how it stitched with them. It makes sense that needle flexing could be causing feeding issues, I can't say for sure if that's my problem or not. I'm not actually having problems per se but I just liked the way it worked better with the smooth feed dogs installed. I get what your saying about opening up the middle foot being useless as a needle guide but its easier to see and that's how the middle feet come with the Cobra machines and I haven't heard any problems arise because of them. As I explained the centre foot isn’t needed as far as needle feed is concerned it doesn’t come into play at all unless you are using fine needles. I also neglect the walking foot mechanism which isn’t common to both unison and needle feed, and the bottom needle guide is important to both, the through plate, feed dog is a must for unison feed, as is the centre foot otherwise you have needle feed jump foot. As long as you have the bottom needle guide no problem. Quote
Members leatherkind Posted March 3, 2013 Members Report Posted March 3, 2013 I am too very happy with my cowboy 4500 from Toledo. I however had troubles with using a stirrup plate. First necessity to remove the feed dog was annoying. Eventually I resolved that by grinding the bottom of the plate off to allow anough room for the dog. http://leatherworker...70 That seemed to work but the plate had one lip quite narrow and it would leave a groove on leather. In addition i could not use left sided saddle presser foot because it was too far to the left from where the elevated part of the stirrup plate was and with softer leather it was a mess. I decided to give it a try and make a custom stirrup plate. After couple of messups and model adjustments since yesterday I had a working prototype which actually seem to work. The plate might look a bit weird because it is made out of ABS plastic (3d printer was used). It turned out to be quite strong and does not flex at all even with thick leather #27 needle and 345 thread. I also made the needle slot as narrow as possible and there is a cutout on the bottom for the feed dog which allowes me not to remove the feed dog and quickly swap plates. It also did not leave any significant markings although the thread tension is a bit too high. I will keep my fingers crossed and hope it works for some time. Quote
Moderator Wizcrafts Posted March 3, 2013 Moderator Report Posted March 3, 2013 I am too very happy with my cowboy 4500 from Toledo. I however had troubles with using a stirrup plate. First necessity to remove the feed dog was annoying. Eventually I resolved that by grinding the bottom of the plate off to allow anough room for the dog. http://leatherworker...70 That seemed to work but the plate had one lip quite narrow and it would leave a groove on leather. In addition i could not use left sided saddle presser foot because it was too far to the left from where the elevated part of the stirrup plate was and with softer leather it was a mess. I decided to give it a try and make a custom stirrup plate. After couple of messups and model adjustments since yesterday I had a working prototype which actually seem to work. The plate might look a bit weird because it is made out of ABS plastic (3d printer was used). It turned out to be quite strong and does not flex at all even with thick leather #27 needle and 345 thread. I also made the needle slot as narrow as possible and there is a cutout on the bottom for the feed dog which allowes me not to remove the feed dog and quickly swap plates. It also did not leave any significant markings although the thread tension is a bit too high. I will keep my fingers crossed and hope it works for some time. I would like to get one if yours holds up. Contact me via the PM feature. I have other things in mind that you might be able to "print" for me in plastic. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members billymac814 Posted March 3, 2013 Members Report Posted March 3, 2013 Me too. I put my feed dogs back in because I like them better, if that works out let me know and I'd be interested. Another thing that would be nice is a plate just like the one used with the feed dogs but without the grooves Quote www.mccabescustomleather.com
Trox Posted March 4, 2013 Report Posted March 4, 2013 (edited) I am too very happy with my cowboy 4500 from Toledo. I however had troubles with using a stirrup plate. First necessity to remove the feed dog was annoying. Eventually I resolved that by grinding the bottom of the plate off to allow anough room for the dog. http://leatherworker...70 That seemed to work but the plate had one lip quite narrow and it would leave a groove on leather. In addition i could not use left sided saddle presser foot because it was too far to the left from where the elevated part of the stirrup plate was and with softer leather it was a mess. I decided to give it a try and make a custom stirrup plate. After couple of messups and model adjustments since yesterday I had a working prototype which actually seem to work. The plate might look a bit weird because it is made out of ABS plastic (3d printer was used). It turned out to be quite strong and does not flex at all even with thick leather #27 needle and 345 thread. I also made the needle slot as narrow as possible and there is a cutout on the bottom for the feed dog which allowes me not to remove the feed dog and quickly swap plates. It also did not leave any significant markings although the thread tension is a bit too high. I will keep my fingers crossed and hope it works for some time. Thank you leatherkind, I have been following your post regarding the 441 stirrup plate and its limitations. And of course, I agree with you, the plate is useless the way it is. I was planning to modify my plate the same way you did your. However, the narrow left side made me realize it can never be any good. I make me wonder if the constructor even cared to try it out, before mass-producing it. The 441 with its long needle system need a lower needle guide. If not a feed dog, a modified feed dog or a real Ferdco pat. lower needle guide. Your ABS plate looks exactly as the stirrup/bag plate should look like. Have you considered letting somebody make it in steel. I may know a company who is interested in making it, a company who makes sewing attachments. Even if the ABC plastic would hold up well, it looks like the ruff surface of it will slow down the leather feeding. Or is the surface smooth enough? To get my purchased stirrup plate to look like that, it has to be shopped and built up with weld (on the left side). (And grinded and polished of course) I do not know if it will be any good after welding, it a risky business. Maybe brass welding would do the trick, I do not know for sure. I have also considered that steel weld (even after been polished) might color wet leather black. All available 441 stirrup and holster plates have this stupid narrow left side. They all have to be from the same factory. It is important that this factory get some constructing feedback. The same line of attachments also produce feet’s of different height, which means you have to adjust the machines alternating height when you want to combine any of these feet’s. There is only one corrects height on these feet’s all others are errors. We can keep on spending our time modifying all what we buy or ask more from our dealers. I think we must ask for more quality to get it, let’s put some pressure on the Chinese makers. If they do not want to make proper stuff, there is other who will. Thanks Tor Edited March 4, 2013 by Trox Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
