I hate to even ask, but apparently a lot of gun manufacturers are not shipping to New York. I need to make the holsters for my CAS rig and I don't have my guns. What is your typical width for the belt loop on a Colt clone loop holster? I am running out of time for the first event. I need to plan my belt as it is the only thing I can make. I appreciate any insight.
Thanks,
Ken
I use a piece of leather that I cut a tad wider than 3/4 inch. I do that so that when I pull it through the 3/4 wide slots, . . . it will not slide back.
Hope this helps.
May God bless,
Dwight
www.dwightsgunleather.com
all the cas rigs i have seen are 2 1/2 inch wide belts the holsters i have made for cas will fit a 2 1/2 "belt
keep it in the 10 range or at least hit the steel.
Thanks for the help guys. I appreciate it.
