  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Has any one used the Dremel work station turns rotary tool into a mini drill press?
Seems like it would speed things up by drilling the 200+ holes instead of punching?
Edited by paprhangr
I have a Dremel work station set up on my table works great for putting the holes in. Your seat looks great very nice job.
I think the holes are a lot cleaner from punching. But, there are a lot of people who use the dremel with success. I use my dremel press with a burnisher in it for 2 handed guiding of the work through the burnisher.
  • 2 weeks later...
hows that work? sounds like a drill press is handy to have for leatherwork
If you haven't seen what the dremel press is, it's a little device similar to a drill press that you attach a dremel to and it lets you move the dremel up and down in a controlled fashion. But, it also incrementally rotates 90 degrees. I have mine setup horizontally with the my dremel burnisher so I can see what's going on a lot easier and just run my belts and guitar straps through it real quick with both hands.
This is the one I bought, but it looks like they have a different version now. If you're interested in it, keep in mind that it's only technically compatible with certain models of dremel. They're all listed there I think. Basically, it just has to fit in the carriage. I had another battery operated dremel that wouldn't work on it, so I went and bought a new one to fit the press.
http://www.amazon.co...8952287-0599345
I don't think it's a replacement for an actual drill press, but as far as burnishing and sanding, it's pretty handy in order to keep both hands free. I'm actually looking for a full size drill press right now, but I need to get a new bench built to house stuff like that.
Edited by Cyberthrasher
i picked up a $90 bench top drill press at HF, on sale $60,
Drill presses are very handy in leather work. I use both a full size drill press and a dremel drill press. I keep one of Bearman's burnishers mounted in the large drill press, works great, use it on almost every job.
Great looking Seat, excellent job, glad the video helped.
Chief
"Life's too short to carry ugly leather"
thanks Chief, could you explain how to burnish using a large drill press (or a link)
im new and have only used a edger and a slicker
Questions:
has anyone made a bobber/chopper seat pan out of fiberglass?
when using the drill press, is there a drill bit that will make a clean hole in leather?
