Members stef73433 Posted March 18, 2013 Members Report Posted March 18, 2013 What is the secret to this spot setting tool? Alot of then don't set straight in, they slide sideways, ruining the prongs and leaving extra marks.what an I doing wrong? Quote
Contributing Member TwinOaks Posted March 19, 2013 Contributing Member Report Posted March 19, 2013 Very similar to snap setters, the trick is many light taps instead of hard hits. Adjust as you go. Quote
Members stef73433 Posted March 19, 2013 Author Members Report Posted March 19, 2013 Thank you.that seemed to help. Quote
Members Grimsin Posted April 13, 2013 Members Report Posted April 13, 2013 Very similar to snap setters, the trick is many light taps instead of hard hits. Adjust as you go. I find that the lighter hits help, I was trying to train an employee the other day using the mallet and setter technique, it was painful. I sent them over to the press for the rest.... Quote
Members VanHornSaddlery Posted April 22, 2013 Members Report Posted April 22, 2013 Hello, I set a lot of spots in chap legs and spur straps. I use a chunk of heavy skirting leather underneath to drive the spots into on my tooling block and use my heaviest tooling hammer to drive with. One whack is all it takes per spot, then peel them up, tap studs over whith small tack hammer, flip over, move leather and repeat, just taught my wife to spot chaps and couldn't be happier than a fox in a hen house, She is doing great, you will get the occasional obstinate spot that has to be pulled and redone but not very many. For me the secret is getting the legs in the middle of the setter and hitting straight down each time. Easier said than done, but with practice is pretty quick. Happy spotting. Jake Quote
Members TIMCO now SX Posted January 8, 2014 Members Report Posted January 8, 2014 Check out our New Spot Setter! I will be happy to send you all the info. With over 30yrs in the leather industry, you can be sure our spots will do the trick. New member as of last night....sorry for the delayed reply. Happy New Year ! Tim Quote
Members horseplay Posted January 13, 2014 Members Report Posted January 13, 2014 I do alot of hand setting of spots and would second what Jake stated above. I also use a piece of heavy leather underneath. It works very well overall. I do have more trouble setting brass spots vs steel spots though. Quote
raysouth Posted January 13, 2014 Report Posted January 13, 2014 Hello Tim, Send me the info on the new spot setter. Thank you and God Bless. Ray Quote
Members TIMCO now SX Posted January 14, 2014 Members Report Posted January 14, 2014 (edited) Hi Ray, Here is the link to view our spot setter in action: You will need to go to youtube site to properly view http://www.youtube.com/watch?v=F8YaGrx9cVg&feature=em-share_video_user Edited January 14, 2014 by TIMCO now SX Quote
Members TIMCO now SX Posted January 14, 2014 Members Report Posted January 14, 2014 Hi Horseplay, We do our best to use the same hardness level for both steel base and brass base spots. This allows our customers to use brass base spots for high end work and steel base for low budget items....on the same machine and die set. The same can be said for our Stainless Steel as well. K. regards, Tim Quote
