Members Dwight Posted March 26, 2013 Members Report Posted March 26, 2013 My process either uses a known and proven pattern where the pieces are cut, glued, edged, and sewn before any molding, . . . OR, . . . the pieces are cut a bit big, . . . part of it is cemented (maybe sewn, it depends) and then the holster is molded to the gun. The second process is by far the most common that I do. After molding, . . . it has to dry, . . . and for me that is 24 hours, . . . no short cuts there. I then re-insert the gun, . . . close up the holster with one hand, . . . and mark the edges for cutting. After cutting them, . . . I contact cement the edges together and then comes the dressing process. It starts with a 1 inch wide belt sander, . . . which makes all the leather layers even with the others. That also gives the outside edge it's final "shape" of the silhouette of the holster. After sanding, I edge the whole thing, . . . inside, . . . outside, . . . left, . . . right, . . . top, . . . bottom. Take your time here !!!! Get it right. Sometimes this is where I do a first burnishing of the edges, . . . dremel tool and water only, . . . then when I start with my stitch gouger, . . . it slides along the edge very easliy and I don't have to tug on it. After sewing, . . . dying, . . . and drying, . . . I'll sometimes come back for a second burnish before the finish, . . . other times after the finish, . . . depends on the finish product I am using, . . . Very seriously, . . . not dressing up, cleaning up, burnishing, and making the edges look good, . . . to me looks like a brand new car that just came off the line with no chrome, no trim, and a flat paint job. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members brianjaa Posted March 27, 2013 Author Members Report Posted March 27, 2013 Brian, see Nigel Armitage's video at the link below: This is a great video tutorial about how to make holes through multiple layers of leather. Nigel is a true master of the art Thanks for the video. It really is good. When you see it like that it is so simple. Thanks again. Quote
Members Monkiller Posted April 6, 2013 Members Report Posted April 6, 2013 Thank you for the informative tutorial. Quote
