stef73433
Barge Not Sticking
I glued a piece of cased leather down for past of ground seat tonight.I had issues with it sticking to the metal seat strainer. It wouldn't set up and get sticky.I pulled it off, wiped of all glue I could and tried again.seemed to work better second time.
Could it be,I didn't let glue set long enough to get sticky
Probably didn't let it set long enough. Normally 15 minutes to half an hour is sufficient. Sounds as though you may have had some oil or other residue present.
ferg
