Members bjbwt2 Posted June 29, 2013 Members Report Posted June 29, 2013 Pancake holster - I see some of you keeping the belt slots vertical (perpendicular to belt) and others angling them slightly forward or backwards. Is this purely for aesthetics or visual appeal? Does one method provide better longevity or wear? I've always angled because I like the look and it seems to use a little less leather. Quote
Contributing Member SooperJake Posted June 29, 2013 Contributing Member Report Posted June 29, 2013 I like vertical slots aesthetically, and they don't seem to torque your belt out of whack as much. Also, your overall holster can be shorter. Quote
electrathon Posted June 30, 2013 Report Posted June 30, 2013 I think angling them is a matter of form over function. A slanted hole is longer and can allow the holster to shift and rotate out of position easier, straight holes hold the holster tighter into position. But they look cool. Quote
Members bjbwt2 Posted June 30, 2013 Author Members Report Posted June 30, 2013 When you say the overall holster can be shorter do you mean length? Height should be dictated by length of barrel right? Thanks for the replies. Quote
Contributing Member SooperJake Posted June 30, 2013 Contributing Member Report Posted June 30, 2013 When you say the overall holster can be shorter do you mean length? Height should be dictated by length of barrel right? Thanks for the replies. Yes, the overall length can be shorter. Quote
