That is exactly what i needed Goldshot! Very nice step by step.
I am on the right track, hurray! thanks!
OK...that's a photo I posted earlier this year. This saddle had a rear jockey so the installment of the flank ring is different than a set of skirts without a rear jockey. With that said: first, determine the design of your skirts and block them. This is easier done prior to putting in your seat. After installing your seat, come back to your skirts and align your top piece. Cut your leather oversize on the outside edges of your bottom piece. Using rubber cement glue the bottom and top pieces together to insure fit. Fitting up includes rigging placement.
When satisfied with the skirts on the tree, remove the skirts from the tree (without pulling the cemented skirts apart) and compare them to each other to insure they're alike. Trim your top piece to match the bottom piece and attach your rigging plates and dees. Check your edges once more, sanding them if necessary to insure that they are cut at a 90 degrees. When satisfied, sew them together about 3/8ths of an inch from edge.
If your skirting leather is light weight, you can install filler pieces as you would regular skirts; however, this isn't necessary with heavy weight leather and does increase bulk.
These skirts are held into place on the bars with screws at the fork, at the cantle corner at the bars (covered by seat jockey), and rear rosettes or conchos.
The sheepskin is installed as usual and the sitch line is about 3/16ths from the edge.
I'm old, but not an old saddle maker. This method has worked for me on three saddles without any client complaints, knock on wood. Hope this helps,
Ron
When you say sheepskin installed as usual, could you explain what "usual" means to you? (when in the process would you sew it and would you sew to just bottom layer, or to both layers of skirt? I dont like the look of the 2 rows of stitching, but i will do it if not a better way.
My usual way of preparing my skirts is the same way as you'll find in the Stohlman books. The top of the skirts and the filler pieces are glued together, then the sheep skin is glued to the skirts, and one line of stitching holding everything together.
However, I feel when using inskirt rigged saddles the extra stitchline helps reinforce the skirts to make the saddle more secure and stronger. I've seen too many inskirt saddles where the stitching has rotted away or torn, and the only things holding the saddle to the horse are a few concho screws.
You can use a single stitchline if you want to prepare your skirts. There are no set rules. I tend to over engineer everything I make just to be safe.
