Members Ian1783 Posted August 11, 2013 Members Report Posted August 11, 2013 My latest acquisition, a Chandsew 406RB, requires Spindle Oil, which isn't something I've heard about or seen until googling it; light, low-viscosity oil. 3 in 1 Oil is spindle oil apparently. Hydraulic fluid was mentioned. I don't recall what I used for my Consew 206RB-3 (of which the Chansew is, essentially, a clone), but I'm sure I just used whatever sewing machine oil (domestic) I had lying around. Is there a substitute, or more readily found oil that will work for this machine? Will regular home sewing machine oil work? My Singer 153W103 is supposed to use type B or type D oils. Type B is a "stainless" oil, as spindle oil is supposed to be, so is it in fact spindle oil? Will hydraulic oil work for both of these? Or can I use 3 in 1 for both? Or, again, regular sewing machine oil? I've heard Zoom Oil, which can be purchased at Home Depot, can be used. But googling Zoom Oil shows oil in a bottle with an applicator spout, which seems to be the selling point, rather than the oil. No real mention of just what the oil is, other than fine, paraffin-based, all-purpose oil. Of course, I won't be using my machines in a commercial setting. More like slow, occasional, hobby-project uses. Bottom line, what should I use? Ian SF Bay Area http://imcinnis.blogspot.com/ Quote
Moderator Wizcrafts Posted August 11, 2013 Moderator Report Posted August 11, 2013 Your Chandler or Consew uses the same industrial Lilly Oil as most other industrial sewing machines. You can buy it in 4 oz bottles, quarts and gallons from most industrial sewing machine dealers, including Toledo Industrial Sewing Machines. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ian1783 Posted August 12, 2013 Author Members Report Posted August 12, 2013 Thanks, Wiz. I just heard of Lily Oil today. Much to learn. Ian SF Bay Area http://imcinnis.blogspot.com/ Quote
Members GerryR Posted August 12, 2013 Members Report Posted August 12, 2013 (edited) Ian, Mobil Velocite No. 10 Spindle Oil (ISO Grade 22) is the same as the Lily oil. It can be bought here: http://www.mcmaster.com/#spindle-oil/=o13t0u I don't know the price difference, but it is another optional source. Gerry Edited August 12, 2013 by GerryR Quote
Members Cascabel Posted August 12, 2013 Members Report Posted August 12, 2013 It can be found on ebay fairly inexpensively. I bought a gallon several years back, and have plenty for a long time. Just enter "sewing machine oil" in the search window. Quote
