Thank you all!
I use clear ~1/4" plexiglass for my permanent templates and molds, not a good as polyethylene and a bit more brittle but I can see through the template so it helps me to position it. I then scribe stitch lines, fold lines, drill location holes etc. on to / through the plastic template. I can cut it with a small cheap band saw ($60 on sale) from harbor freight using a metal band saw blade and like Tex Shooter said, I cut it a tad over sized and sand (Harbor Freight 4" belt and disk sander - $80) it to the correct size.
  • 1 month later...
Wow - that breast strap is absolutely gorgeous!!!!!!!!!!!! I think it looks amazing as is.
~Kate
