Members benlilly1 Posted August 25, 2013 Members Report Posted August 25, 2013 What are the best methods of burnishing a flat piece of leather? Moisture content? What to burnish with? To get that worn look. Quote
Contributing Member Bob Blea Posted August 26, 2013 Contributing Member Report Posted August 26, 2013 Good morning, How big of a piece is it? I'm guessing you want to burnish something the size of a motorcycle seat? I've seen saddle makers use a tool (I believe it's usually called a bouncer) that is a round knob on the end of a stick. They use it like a bone folder to work the seat of a saddle down into the tree and into the shape they need. When I've seen it done the leather is very wet, just like wet forming, and it doesn't seem to burnish much. However, I think if the leather was very dry, like for tooling, I think it mightburnish it. The key will be applying a lot of pressure when you do it. When tooling I can burnish a small area with the rounded end of my stylus though it's not a really dark burnish like you get when tooling. I don't think it will be easy to do a large area that way. If you can find a small smooth round knob and rub that over the leather with a lot of pressure it might work. Or, do you have a press? A smooth flat plate might work if the leather was cased but pretty dry. for what its worth, Bob Quote
Members benlilly1 Posted August 26, 2013 Author Members Report Posted August 26, 2013 Thanks Bob, yes larger pieces of leather. Just like you've suggested, I finally found a few threads here on the subject. Also a smooth piece of walnut is suggested. I agree it's not going to be easy to keep it consistent. A plate's a good idea. Quote
Tree Reaper Posted August 27, 2013 Report Posted August 27, 2013 A palm sander with the sand paper epoxied to a thin piece of hardwood might work. Sand the edges of the wood upward to keep it from digging into the leather. Quote
