Members chiefjason Posted September 1, 2013 Members Report Posted September 1, 2013 Anyone have a good reference or pointers on the Boss? I have a lead on one locally that I will be picking up next week to test drive. A friends brother bought it and it's sat in a shed unused for years. I'll be doing a lot of web searching here soon. But thought I would ask here for any good references. Thanks! Quote
mlapaglia Posted September 1, 2013 Report Posted September 1, 2013 If its been in a shed for years clean and lube it BEFORE you do anything else. Then watch all the videos on tension set up. Tension is the biggest issue with a Boss. I have one and love it. If you buy it send it to Tippmann and get it gone over. It will be worth it since its been in a shed. Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members supercub Posted September 1, 2013 Members Report Posted September 1, 2013 Yep, pay attention to tension. You will likely initially set more tension than what you need. Loosen the bobbin tension to only around a pound or two and adjust the top thread tension for a good stitch. Also, pay attention to sewing technique. Make sure the needle is still in the leather ( around a quarter inch up from the bottom stroke) when you make a turn. Don't short stroke the handle, make sure you make a complete motion of the handle or you WILL get missed stitches. The Boss takes a little effort to get used to, but once you get it set up and understand its quirks, it will do a good job for you. Even though I have a Pro 2000 that usually works very well, I still use the boss for a lot of work that needs close accurate stitch placement. Quote
Members chiefjason Posted September 1, 2013 Author Members Report Posted September 1, 2013 Thanks guys. I found the Tippmann channel on youtube and watched the introduction video last night. I was surprised at how simple the machine seems to be. The tension adjustments are similar to those on my rod building/rod wrapping lathe. And I've got some time on a standard sewing machine so the lower bobbin area looks pretty similar, and probably easier to deal with. I feel like a kid waiting on Christmas. lol Quote
