Hello!
First, thank you to all of the experienced leatherworkers for shinning such awesome insight! Based on the forums, I just purchased a Consew 225, a great machine to sew through the double layers of 1/8" leather I plan to use to make bags.
Here is my question: The pressure foot that is on my machine has teeth on the bottom, which leave marks on the leather. Is it recommended to sand down these teeth? Or is there an alternate foot that I should try?
Thanks again for all the wisdom, what a great community!
Dana
You might wanna just get a set of 'smooth' feet, save the toothy varmints for zippers n such. Set a feet for that thing kaint be more'n a few bucks. Bob prolly got em in stock
http://www.tolindsewmach.com/
Standard foot set for Consew 225 is smooth bottom, should be easy enough to find. Consew 225 parts book lists the inside and outside feet with the correct part numbers your looking for.
Great! I did get the parts from Toledo Sewing Supply and it was very easy to install :)
