Hi to all!
Ok, the title is not of the best, but I had no other words to explain my problem...
That's simple: I would like to obtain decorations similar to the border on this purse: http://www.leofficinecreative.com/la_bottega_itinerante/img_cuoio/borse/borsa_cuoio_26.jpg
and, generally speaking, how to achieve a similar result, with decorations lighter than leather's color, without using leather colors...is it possible?
Thanks in advance!
You have to paint on a block out or resist to the areas you don't want dark prior to applying the dye.
  • 2 weeks later...
Would it give you the same effect if you dye the leather and THEN carve into it???
