Members Petro49er Posted April 6, 2016 Members Report Posted April 6, 2016 Thanks Sylvia. I thought I had. And thanks for setting up this whole setup with goldstar. I tried contacting Buckleguy to see if I could buy a small quantity to test with my press and they wouldn't allow me to do so. I've also only had issues with ligne 20 from Ohio Travel Bag. I had no ligne 24 to test with. All that said, the ones from Goldstar work fine; it's just nice to have options. Quote
Members dq7133 Posted April 6, 2016 Members Report Posted April 6, 2016 @Petro49er I would also add that the quality with Tandy seems to be hit-or-miss, so as @sylvia suggested, you might have to do some experimenting. I don't use snaps often, but the ones I do use were purchased from Tandy about 6 months ago. Both ligne 20 and ligne 24 work fine for me. Quote
Members robb01 Posted April 7, 2016 Members Report Posted April 7, 2016 Anyone know if the double cap rivet die will work for multiple sizes of double cap rivets (6mm, 7mm, etc.)? Quote
Members Hime by Jaime Cole Posted April 27, 2016 Members Report Posted April 27, 2016 Cache Money Members 4 posts Posted 14 March I just called and brokered my deal. Deal price changed last month. It is now at $99.96. 1. Machine. 2. Dies Ligne 20 snap 8mm Double Cap 3mm hole punch that will work for ligne 20 and 8mm double cap (no more hammering those!) 3. 100 Brass Double Caps Can you please tell me where you brokered this deal? I'm looking for a handpress that will fit many sizes. Thanks! Quote
Members Sylvia Posted April 27, 2016 Members Report Posted April 27, 2016 The deal is found at Goldstartool.com call them and ask for the "Sylvia Leather" deal. Since this deal was originally set up a few years ago it may indeed be 99.99 or so. But considering that Tandy charges over $200 for the machine and $100 for the dies I think this is a great deal. On 4/7/2016 at 9:16 AM, robb01 said: Anyone know if the double cap rivet die will work for multiple sizes of double cap rivets (6mm, 7mm, etc.)? The dies are sized for the rivets. That said you could probably use a 7mm one to set a 6mm rivet, but considering the dies are so cheap, I recommend that you get the correct size. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members qlthreadhead Posted May 9, 2017 Members Report Posted May 9, 2017 On 4/27/2016 at 5:16 PM, Sylvia said: The deal is found at Goldstartool.com call them and ask for the "Sylvia Leather" deal. Since this deal was originally set up a few years ago it may indeed be 99.99 or so. But considering that Tandy charges over $200 for the machine and $100 for the dies I think this is a great deal. The dies are sized for the rivets. That said you could probably use a 7mm one to set a 6mm rivet, but considering the dies are so cheap, I recommend that you get the correct size. Sylvia -- you just saved me so much money. I have a very old Stimpson 489 (American made) that I broke over the weekend (got a die stuck, warped the housing upon removal) that I needed to replace. Also moving cross-country in a few months so wanted to downsize. I'd been researching all afternoon and came across this thread -- happy to say David is still honoring the Sylvia deal -- ran me $99 for the green machine, and he let me build my own combination of dies (I chose his spring snap ligne 20, ring snap 24, and double cap rivet 8mm). I work almost exclusively with Ohio Travel Bag snaps and will update this post once I have tried to set them with my new setter. Back up plan is to buy the individual dies from OTB (around $30 per die!) for the buttons if needed (someone else mentioned they got the buttons stuck in Goldstar's die). Thanks again! Quote don't fall off the roof....
Members Sylvia Posted May 11, 2017 Members Report Posted May 11, 2017 On 5/9/2017 at 3:09 PM, qlthreadhead said: Sylvia -- you just saved me so much money. I have a very old Stimpson 489 (American made) that I broke over the weekend (got a die stuck, warped the housing upon removal) that I needed to replace. Also moving cross-country in a few months so wanted to downsize. I'd been researching all afternoon and came across this thread -- happy to say David is still honoring the Sylvia deal -- ran me $99 for the green machine, and he let me build my own combination of dies (I chose his spring snap ligne 20, ring snap 24, and double cap rivet 8mm). I work almost exclusively with Ohio Travel Bag snaps and will update this post once I have tried to set them with my new setter. Back up plan is to buy the individual dies from OTB (around $30 per die!) for the buttons if needed (someone else mentioned they got the buttons stuck in Goldstar's die). Thanks again! I am glad David was able to help you. I've been happy with both of my machines. I bought one and he gave me one. Most recently I got a serious electric cutting tool. It can cut 10oz HO saddle leather like NOTHING... only thing is it doesn't do curves. But If I need a straight line... it's awesome and it self sharpens!! (a huge deal for me.) check it out. https://goldstartool.com/Electric_rotary_cutter_4_inch_RSD-100.html Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Fitzcrew Posted August 27, 2017 Members Report Posted August 27, 2017 I was quite pleased to find this thread via a reddit post regarding hand presses. I have looked at most of the presses offered out there, and they all are similar in how they are made and function, so it comes down to dies and costs. Hands down the "Sylvia Leather" deal is tops, if still available. I will be making the call this week and will report back on availability of the deal. Quote
Members hanns Posted August 27, 2017 Members Report Posted August 27, 2017 I've been seriously looking at the Gold Star hand press and I just read through this entire thread (most info I've found anywhere!). I sent in some rivets I have (3/16" mild steel semi tubular), but he doesn't have any dies that work with them. I share the same concern as some others here - I don't want to be locked into only using their hardware. I want to be able to source rivets and dies from other places as needed. Does anyone know of other shops that sell dies that work with this machine? I'd also be really interested to know what sorts of rivets this machine can handle. Steel semi-tubular ones are a bear to set. I love them for their strength, but setting them properly is tough. What size/material rivets have you been able to set well with this machine? Quote
Members bb8it Posted January 17, 2018 Members Report Posted January 17, 2018 Well, to throw in my two cents on this issue of Hand Presses. I am retired and one of my hobbies is working leather. So I'm no expert leather worker, that said, here is what I have found out about hand presses for snaps, grommets, and rivets. There seems to be no common size, or terminology between the different countries, manufacturers, or vendors when discussing these machines and dies. And they all want theirs to be proprietary machines and dies so you spend all your money with them ( one my pet peeves, the word proprietary) /. But having spent several hours/days reading and researching, I'm still pretty confused. But I am resolving a few of my issues and problems. The "green hand press" directly from China has dies that are 19 mm base hole with a top thread of 8 mm.(see pics) KAM presses do not have threads but a grooved tang that you tighten a set screw to hold. I didn't like this method as I can never find an allen wrench the right size when I need it, and I hate breaking up sets of wrenches to dedicate one just for one use. But I do like the bottom die as it has a 'button' you push to insert it and when released, holds the bottom in. Kinda cool, but not worth having to look for an allen wrench for the top die. Gold Star dies are smaller, not sure of bottom diameter but the top thread is 1/4" x 24 which is not a common thread. SAE common threads are 1/4"x20 course and 1/4"x28 fine. I like Gold Star dies, but had already purchased a "green hand press". I have only seen pictures of the Tandy dies, but they are expensive. So are other brands I have seen especially the commercial machines. The Chinese dies run between $9 to $15 dollars a set, the guy in the UK sells dies for roughly $20 a set, and I have seen them on ebay from $9 to close to $50. Most of mine are the $9 variety with me breaking down a buying some that are special that cost $20. Like the Gold Star pearl snap dies. So what I did was this, I have an old atlas 6" lathe so I turned a small insert so the gold star dies 'fit' the bottom hole, then I took an 8 mm bolt and in my lathe, drilled and tapped it to 1/4"x24 (had to buy a special tap to thread this). Now I can use the Gold Star dies in my green machine. I also had to drill another hole in the threaded shaft to allow me to move the shaft up slightly, as clearance between the dies are set for the "green machine" dies and with the Gold Star dies with the modified insert and 8mm threaded bold there was not enough room. but with a hole about 1/2" down from the original, and by removing some of the bolt hex head to 'thin' it up, and the bottom insert only has a thin 1/4" or so, lip, I am happy to say it seems to work great. The second hole in the shaft is pretty easy to move and so I removed the cotter pin and use a nail to slid into the hold between the body and springs as the spring holds the nail in place securely enough to use it but is easy to pull out and move to the other hole to switch between dies/inserts. I have ordered some more dies, both from Gold Star (their pearl snap dies are the best for setting peal snaps as they are Teflon lined to prevent marring the button snap) I have the three common spring snap dies from china (831 etc.) and ring snap dies are ordered. I have single cap rivet dies from the UK vendor coming as well. So I'm still learning and putting this machine and dies together. But in a few months I will have almost all of the operations figured out. Just to mention grommets, they seem to be more of a 'standard'. And I have had very little issue with grommet dies and setting grommets. My dies punch the hole and set the grommet in one operation and as long as you have the correct grommet die size in the machine, they come out without marring or bending and look clean and hold very tightly. Hope this helps anyone just getting into hand presses as I had a real hard time learning the differences without wasting precious resources in getting this setup. I will have to revisit is once I get all my dies in and get the process of using them down. As I found it a very confusing and way too complicated an issue since every vendor wants to make theirs unique so you have to buy all of your items from them. Quote
