Members Camerius Posted July 10, 2014 Members Report Posted July 10, 2014 I got a Chinese 11 part rivet setting set for about 10$ including free shipping from ebay. Works as it should and intended. Quote
Members Sylvia Posted July 10, 2014 Members Report Posted July 10, 2014 Camerus... are you talking about a set of hand tools and anvils? That's a good price. It is just that many of us have issues with hand setting rivets and snaps. As for myself, even with antique hand setters that have a good ridge around the edge, I would fail to get a good roll and the snap would pull right off.... Or worse the newer tools I have would drive past the ridge and just flair the tube and not roll at all and again.. the snap would pull off.. the $90 was well worth the investment. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members RavenAus Posted July 10, 2014 Members Report Posted July 10, 2014 For a press or hand-held? Sylvia, for me the problem is the cap almost always moves, no matter the setting tools I'm using, so the tube bends and the snap pulls off... This is why I was so excited to see them here in Oz! Quote Kind regards, Raven http://wolfscrafts.com/
Members Sylvia Posted July 10, 2014 Members Report Posted July 10, 2014 LOL oh yes and that too... I've actually found myself angry enough to beat the rivets so hard that the metal cap tore... lol That's when I started turning down jobs that required rivets or snaps... unless I could convert them to buckles... I just would gracefully as possible decline the job. Some of that "moving" is a problem with too long of a stem on the snap or rivet... but I so know what you mean... GRRRR. lol Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members tossik Posted July 10, 2014 Members Report Posted July 10, 2014 Sylvia, can you tell me how the dies are attached to the press? is it thread? if so what is the size of it? Any chance for a photo? I was thinking that perhaps I can use the these dies (can't beat $20 per set) and fit them into the CS Osborne press. This way I can use the press for my makers mark as well as all the riveting and snapping tools. Quote
Members Sylvia Posted July 10, 2014 Members Report Posted July 10, 2014 Hi Tossik. Yes the top dies are threaded, the bottom dies are drop in. I do not think they will fit the Osborne press without an adapter of some sort. However it might be worth the $20 to see if they would work. Not sure I can get a photo to post here... but I'll try. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members tossik Posted July 10, 2014 Members Report Posted July 10, 2014 That is perfect. I think I can get an adapter milled. Thank you so much Sylvia for the photo! Quote
Members Sylvia Posted July 10, 2014 Members Report Posted July 10, 2014 I wish I could find my husband's thread sizer doohickey- thingy that would help getting the threads right. You are welcome for the photo.... you are just lucky that I had a set of dies that came in a couple days ago sitting on my desk and my camera nearby. lol I'm about to paint these dies with nail polish so I can quickly grab the pair I need without having to look at the business end of each dye... I'll just grab the purple set. Someday I want to have a block made for them but for now the color coding will have to work. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members tossik Posted July 10, 2014 Members Report Posted July 10, 2014 Well that would be nice, but I am still thankful for the picture you attached. Question- what do you guys use to punch holes with? I got a few hand held punches that I just made a pouch for (http://leatherworker.net/forum/index.php?showtopic=56914) but its all free hand and always not aligned. If I want to do a belt, how and with what should I punch the holes with? The rivets need small holes, but all i see is 1/4 inch hole punches for the press... Quote
Members Sylvia Posted July 10, 2014 Members Report Posted July 10, 2014 Hand punches. I had the most difficult time with aligning holes until I found the Templates that Black River Laser makes. Look here. http://www.ebay.com/itm/CENTERING-AIDS-2-PIECE-TEMPLATE-SET-CRAFTAID-STENCILS-FOR-LEATHER-CRAFT-NEW-/140816612487?pt=LH_DefaultDomain_0&hash=item20c952fc87 It's easy to line up the width of the leather to the lines on the template, hold it down and mark with an awl, then just hold your punch with the leading edge centered on the mark and whack a hole in it. (I tend to have the belt or what ever long-wise going away from me) I've not done it yet but maybe it is something you can work on. Tandy has a handle with several tube punch fittings that screw into it. The screw in part does not fit the press, but I've often thought that an adapter could be made from a rivet die.... then thinking on that... it would almost force you to find the center of the belt, then the width of the holes, mark the placement on either side... a lot of layout time right there. Next I thought about a gang punch for different sized belt widths... and that's $$$ to get made. So I stuck with my hand punches and the Black River Template. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
