I'm going to apply it with a sponge.
Why do you cut it? I've been using it full strength with a brush as a resist. It works ok, if I am patient enough to apply a few coats... and wait overnight. When I'm not patient enough, it doesn't work so good. I found that out with some interesting results.
I'm glad to know it works as a resist.  I was wondering if it did.
  • 4 weeks later...
Minwax now sells a water based laqure.  I use it as a resist.  I think it is comparable to neat lac.
  • 2 weeks later...
Have you tried painting acrylic over the minwax? Does it hold up to bending? Any  info appreciated.
Mop & Glo on leather isn't, and shouldn't be, your first choice for a finish.  I recall the days when I was in the Army and there were always these guys that had to have the shiniest boots on the ground.  Most of us would do the spit shine routine for those special days but being in combat arms it isn't typical to have a mirror like gloss on your combat boots, it just doesn't fit the job.  But, as stated a bit ago, there were some who thought that it would make them "stand out" more so they would get that super high gloss spit shine and then finish it off with Mop & Glo.  I can tell you from 24 years of that life and experience that once you pressed your finger down on the toe cap of that highly shined boot all you would see was a grayish spider web effect from the Mop & Glo cracking.  It is not meant to be used on leather, nor has it ever been meant to; it is a floor finish and intended to be used on hard surfaces.  If an item needs to have that much shine to it there are sources for leather that already has that finish to it.  Not to mention, the chemicals that are contained within Mop & Glo and other finishes that are designed for products other than leather can damage the leather and potentially lead to failure of the leather down the road.
For those who have used the Neat-Lac product of the past and wish to return/continue to use it, the same product is available from Springfield Leather but it is just under another name.  What they sell is in fact the original Neat-Lac and it is still made by the very same company who has been making it all along.  When Tandy let the Neat-Lac product run out and disappear I went on a mission to find its replacement, that is when I ran across the original product and have continued to use it all along.  And, even though it does contain chemicals, everything in the mix is specifically intended for use on fine leather and fine leather goods; it is also oil/conditioner heavy which is why you don't see it cracking when you flex it.
