A lined belt that will equal about 14-16 ounces is the thing for concealed carry. If not, alined belt totaling 10-12 ounces is sturdy and looks very good stitched properly. Single layer dress/casual belt are good.
I have used Welwood for months and the other day it came to me - heat gun. And I read it here somewhere later that day. You use a heat gun on Wledwood to accelerate drying and you better be lined up when you put 'em together. And a rolling pin.
It may have been someone else there Red, . . . but I use a heat gun almost constantly any more. To heck with wasting time (or trying to find something else to do) when all I need done is some weldwood solvent burned off.
So far, I've burned up 2 of them 12 dollar Harbor Freight heat guns, . . . and have even done a stint with my own personal hair dryer (though with what little I have left now, . . . probably ought to sell the dryer,.......), . . . and you are so right, . . . if the glue is dry and warm, . . . where you put it, . . . it sticks.
Part of my reasoning is the way my mind works, . . . if I lay something aside, . . . I have to spend time getting back up to speed on that project, . . . whereas if I can just keep plodding along, . . . I usually will not forget some critical piece like the backing for a concho, . . . a rivet here or a puched hole there. Laying it down while it dries is an invitation for disaster in my poor old codger mind.
May God bless,
Dwight
www.dwightsgunleather.com
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
I use one of these --
http://www.carpettool.net/349_cmyk.jpg
They're heavy, the right width, and enable you to get a lot of pressure down on the belt.
My belts are almost a quarter of an inch thick, so you've really got to press on them .
tk
My two cents worth.
Just use the contact adhesive and when tacky put the two together and press. Make sure they are line up.
You could use a "jewellers rolling mill" but not sure if you would find one at the right price.
I use a modified one for embossing. Picture attached.
Good luck
post-2565-0-39261900-1385972930_thumb.jp
post-2565-0-63028100-1385972943_thumb.jp
post-2565-0-34844000-1385972945_thumb.jp
"Every Day Above Ground Is Good"
A Laminate Roller would be just the thing for what you're doing. They are actually made for, of all things, pressing contact cemented items together! The leverage you get multiplies the force much more than a bakers rolling pin. Lot's of different styles available at multiple places, including Lowes and Amazon.
http://www.amazon.co...Laminate Roller
Edited by evandailey
Just curious if anyone has an easy way for bonding the double layer belts. Typically I just use the contact cement, wait until dry, then bang the pieces together with a 5 pound deadblow but as order volume builds, my elbow and should are starting to hate that method.
I was thinking of something like a pasta roller or maybe an old clothes wringer but figure there has to be an alternative? Tandy has an embosser that I am considering modifying but I hate to gamble with 500 bucks.
What do you guys do?
this is what i use...lowes had them for 10 bucks or so...
post-30702-0-23686900-1386129651_thumb.j
Havoc Holsters
  • 2 weeks later...
Curious, why would you make a belt that is double layered? I would think a single ply would work better.
You laminate them to make them stiffer to support an OWB holster more effectively. Stiffer belts don't have to be tightened as much to support an OWB holster, so they end up being more comfortable. Lots of top-quality belts even have a stiffener running the length, sandwiched between the two layers of leather.
tk
I've had visions of finding an old washing machine, with those hand crank ringers on top?
But then thought I was over-thinking the process...I just hand rub the two pieces together with a scrap of leather, never had a belt come apart on me yet.
Rayban
www.rgleather.net
  • 1 month later...
Hey, Shooter, . . . you're spending far too much time thinking about this my friend.
Use a pie dough roller, . . . just don't let your wife catch you using hers.
Seriously, . . . whoever told you that you have to whack it and beat it after you put it together just seriously does not know the product. I've been using Weldwood since the late 60's on furniture, cabinets, leather, cloth, and probably stuff I don't even remember.
I just . . . NEVER, . . . EVER did anything more than push the two together with a rolling pin or something similar and have again NEVER had a customer complain.
The word contact means touching, . . . not beating, . . .
May God bless,
Dwight
Yep, a rolling pin ought to do the job. You might even be able to find a marble one to match your slab.
I've been using my little A frame press with some press blocks to bond the pieces. Seems to be working fine and is saving lots of wear and tear on my elbow!
