Well having recently come into a little bit of unexpected cash I decided to treat me to a new{reconditioned} machine and after an extensive web search I found just what I needed.only 25 miles from home,thanks to Advance Enterprises Wrexham.
For the princely sum of £559.UK pounds /913 US dollars
Mounted on a new table with a brand new servo motor fitted I found a Duerkopf Adler 269 twin needle cylinder arm walking foot machine with a spare set of feet to run single needle and its "FANTASTIC"!!!!!!
gonna have to do some practicing to get proficient with it but I,m well happy.
Good for you! I just come up with a rust-bucket Adler 205-64 single needle that I’m going to try to get going this winter.
You got a larger photo of yours?
CD in Oklahoma
post-7979-0-11369500-1386543093_thumb.jp
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Hi CD,
Man that is gonna take some work to get up n running best of luck to you with it.
Mine is under a cover in the workshop at the moment will get some better pics later,
It is the same machine as this but on a twin needle set up.
post-22861-0-30586000-1386583428_thumb.j
