Members joeyrsmith Posted January 5, 2014 Members Report Posted January 5, 2014 Guys and Dolls, After adjusting the stitch length this afternoon, I have had some strange and spooky haunted things happen. Has anyone had their machine go "out of time" Dont know if thats the right term. My hook was 180 degrees off until I hit the button again to adjust the stitch a little which made it come back to proper position. Then it started to fray the thread and create birdsnest. Frustrating considering I was sewing great all morning. Kept trying to adjust stitch length with very weird and haunted effects. Then after 3-4 times it broke a needle. Titled it up to take hard long look and decided to give it a break becuz football playoffs started. Any ideas on how to rid it of demons? Joey Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 Sounds like you safety clutch is releasing when you change stitch length. Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 pcox, Please elaborate on the "safety clutch". Very new to industrial machines, I think I read something on that in my manual but have no idea. thx Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 You said you have a manual, read about reengagement of safety clutch It is inside the belt sprocket on the right end of the bottom shaft. Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 Ok will do. Thx Quote
Members cdthayer Posted January 5, 2014 Members Report Posted January 5, 2014 It sounds like you’re pressing the Safety Clutch reset button instead of the Stitch Length button on the deck......? CD in Oklahoma Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 CD, using the manual, I am pressing the button one the deck. It says to wait until it drops then turn until stitch length is set. Lifting machine I see it the pin drops into a cutout on a wheel which keeps the hook from moving. After that I do not know what happens. I do not see a clutch reset button. Sometimes when I have the button depressed and start turning for the length I here another "pop or heavy click sound" After I release the deck button it allows the hook to rotate. I had to do this a bunch of times before the needle and hook were in synchronization again. This morning it seems all good. But I want to know this machine for I will keep it a long time I think. I was worried last night that the hook/needle timing was off, because of the way the needle was dropping and the way the hook was going by. Still trying to find a video or detailed info on the EXACT way that motion works. Thx Quote
Members oltoot Posted January 5, 2014 Members Report Posted January 5, 2014 I got mine new in 1976. It was haunted for about 2 yrs. I guess the ghosts finally figured out I wasn't gonna give up and they did. I did get a MM manual with mine. It is for about 6 different models and instructions are more often than not pick from a list. And things got a lot easier after I accumulated a set of tools that would reach into places without having to block my view with my hands (long T allen wrenches, long screwdrivers, short screwdiver, 90 degree screwdiver). Here it is 2014 and we have developed a good relationship. Hang in there! Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 I think some of you are thinking a 111w and a 211g are the same this not so the 211 only has 1 button in the bed. It adjust stitch length and resetting of the clutch. The clutch is also different on the 211. It is indexed by 3 balls and springs between a hub and shell that makes up the clutch instead of the lever and dog on the 111 Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 (edited) pcox, thx Edited January 5, 2014 by joeyrsmith Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 (edited) you can snug up the clutch action by removing the outer screws and tightening the inner screws a little at a time till you get the setting you want then replace the outer screws to lock the setting. If you tighten too much you will not have any safety clutch protection so go easy. I posted some pictures on your other thread, hope they help Use a padded vise grip to hold the lower shaft and see if you can turn the hand wheel. It should turn with some effort. You may need to spray the stitch adj. unit with some penetrating oil as it may be turning too hard. You always will have to readjust stitch length after you need to reset the clutch, but you should not have to re set the clutch after stitch length change. Edited January 5, 2014 by pcox Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 (edited) I just went and checked mine. I used a leather padded visegrip to hold the lower shaft and can turn the hand wheel with some effort. Adjust just enough to be able to change stitch length without tripping the clutch. Edited January 5, 2014 by pcox Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 Ok thx pcox That is what I was doing then. Tripping the clutch. Is the stitch adj unit in the front head part of the machine? I have no parts list or schematics. Which I think I will search now for. thx Joey Quote
Members pcox Posted January 5, 2014 Members Report Posted January 5, 2014 If yours is like my 211g155 it s the part with the notch in it that the button on the bed goes into. Quote
Members joeyrsmith Posted January 5, 2014 Author Members Report Posted January 5, 2014 COOL Thx Joey Quote
