Recommendation on holster mold for this one? 4" .357
Thought maybe the K frame. Thanks!
The difference will be in the front sight. The adjustable sight models have a higher (and sharper) front sights. The Smith M19 is different than the 65. The K frame showing on the Blue gun store is like the M65 and the M10. Fixed sights. You can use this gun to mold for a M19 and any with adjustable sights. Tape a pencil to the top of the barrel contured to fill up the void between pencil and front sight.
Not sure I understood that... so the 19 is HIGHER?
M19
M10
post-36503-0-63325600-1389122795_thumb.j
post-36503-0-01514300-1389122820_thumb.j
I have always used the pencil thing to mold holsters, especially revolvers. The sights on the 19 will trap the gun in the leather if you make a snug holster and wet form.
A smal dowel rod will work. I actually shape the "upside down" slope on the pencil to match the normal slope of the front sight. In some cases I will groove the pencil/dowel rod to slide around the front sight. Then I wrap masking tape around the pencil and barrel trapping it into position.
If the holster is a pancake or a half pancake this is usually not necesssary because the style creates its own sight channel.
Model 65
post-36503-0-04642000-1389142562_thumb.j
Gotcha. That is the correct firearm and you are a gentleman. This will be an envelope 'western' foldover. That 19 is a LOT taller.
On the glock autos, I have some kabob sticks that are just the right diameter for sight channels.
THANKS!
You are welcome.
