Members veedub3 Posted January 8, 2014 Members Report Posted January 8, 2014 OK I have a customer that I sold a market tote to a few months ago. The bag was not taken care of in that time. Wow she beat this bag up. She is paying to have the straps replaced as her new pup chewed through one of the straps. Now the straps look like she dragged them behind a truck to me. Here is a pic. The strap on the left is a new one from the same hide I made the old one from. I put gumtrag on the flesh side of the old one but can't figure out why it looks so nappy. I only put on one coat, should I have put on more than one coat? Is there anything else I can use to keep the nap lying down? Thanks for the help Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members r lenna Posted January 8, 2014 Members Report Posted January 8, 2014 Check this out http://leatherworker.net/forum/index.php?showtopic=18101 Quote
Members veedub3 Posted January 8, 2014 Author Members Report Posted January 8, 2014 Check this out http://leatherworker...showtopic=18101 Thanks for replying but I am not talking about the edges. I am referring to the flesh side of the strap. More Info: This is what I did to the old strap: I wet with water and burnished with a glass slicker. When that dried, I put one coat of gumtrag on it and let that dry. should I have done anything else to the strap to keep the flesh lying down? Again not talking about the edges. I started with a rather smooth back side to begin with so didn't think it would look like this after just a few months of use. Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members Cyberthrasher Posted January 8, 2014 Members Report Posted January 8, 2014 I would switch out the gum trag for an actual finish product and use a couple coats. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members veedub3 Posted January 8, 2014 Author Members Report Posted January 8, 2014 I would switch out the gum trag for an actual finish product and use a couple coats. Thanks Cyber, I will try that. The folks over at Tandy & Springfield told me this is what gumtrag was for but I have several other finishes on hand I can try. Thanks again. Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members Cyberthrasher Posted January 8, 2014 Members Report Posted January 8, 2014 It's what it's "intended" for, but it's really for sitting in a bottle on the shelf never to be used anywhere. It's a glue it's abbrasive it blocks dye from absorbing it wears off, and as you see leaves a mess. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members veedub3 Posted January 8, 2014 Author Members Report Posted January 8, 2014 It's what it's "intended" for, but it's really for sitting in a bottle on the shelf never to be used anywhere. It's a glue it's abbrasive it blocks dye from absorbing it wears off, and as you see leaves a mess. Ha.ha.ha. I hear ya! Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Contributing Member JLSleather Posted January 8, 2014 Contributing Member Report Posted January 8, 2014 That's a fuzzy sucker, true I check, personally, that the back of the hide doesn't look like this (it shouldn't). But, if you have a piece already, then possibly the most reliabe (and maybe the quickest) way to solve the issue is to line the strap, stitch the edge. A piece of 2/3 or 3/4 on the back will look nice, add some substance to the strap without making it stiff, allow her to throw some oil at it (or saddle soap, or etc ...) easily. Still won't help with the pup. Maybe sell her a new collar that matches the bag? Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members El Zipster Posted January 8, 2014 Members Report Posted January 8, 2014 Fiebings Tan Kote works well on the flesh side. Cheers Zip Quote
Members veedub3 Posted January 8, 2014 Author Members Report Posted January 8, 2014 That's a fuzzy sucker, true I check, personally, that the back of the hide doesn't look like this (it shouldn't). But, if you have a piece already, then possibly the most reliabe (and maybe the quickest) way to solve the issue is to line the strap, stitch the edge. A piece of 2/3 or 3/4 on the back will look nice, add some substance to the strap without making it stiff, allow her to throw some oil at it (or saddle soap, or etc ...) easily. Still won't help with the pup. Maybe sell her a new collar that matches the bag? If the flesh side is nappy, I will run the piece through the splitter to clean it up, but the back side of the strap was pretty smooth to begin with before I burnished then gumtrag'd it. I would have never thought it would have turned into what you see in that photo. But now I know to leave that gumtrag alone.The new piece is from the same hide, it is 6oz veg tan. I thought of adding a lining (I have some 2oz kip from Waterhouse Leather) but I don't have a piece in the shop long enough to cover two 30" straps and I told her I would get it back to her today, so I had to toss that idea out. Yep, it won't help with the pup, maybe keep the bag out reach? Fiebings Tan Kote works well on the flesh side. Cheers Zip That is exactly what I used on the new strap! Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
