BullFrog Report post Posted February 11, 2014 I'm new to leatherworking, having just done a couple simple projects at this point. I am working on my first stitching project with a speedy stitcher sewing awl. I am having trouble penetrating 2 layers of ~7oz veg tanned cowhide with it. I could get it through with quite some effort and a couple of small stab wounds, but I just broke the needle that came with it (which I believe is a #8) trying to push through again. I figure I am doing something wrong here. Any tips on technique? I've just been holding the leather in my hands and pushing the needle through. Thanks in advance! Quote Share this post Link to post Share on other sites
dirtclod Report post Posted February 11, 2014 You'll be money ahead to get rid of the speedy stitcher and get a sewing awl and some needles to sew with. Punch your hole with the awl then push your needles through the holes. Their are several movies on you tube showing how to hand sew. Quote Share this post Link to post Share on other sites
Dwight Report post Posted February 11, 2014 Add to what dirtclod said, . . . make yourself (or purchase one) a stiching pony, . . . Here's how to make one,..... http://www.wrtcleather.com/1-ckd/tutorials/_stitchpony.html Check out you tube for "how to saddle stitch", . . . and put that other thing you have in a drawer somewhere. May God bless, Dwight Quote Share this post Link to post Share on other sites
Tree Reaper Report post Posted February 11, 2014 The problem you are having is caused by not making a hole with a sharp stitching awl first. That speedy stitcher is only designed to penetrate cloth like material without a hole. Quote Share this post Link to post Share on other sites
rawcustom Report post Posted February 11, 2014 Not sure if it is kosher, but I lay out my pattern with a spacer and drill my holes first. Have to use a small bit, maybe a 3/32. Quote Share this post Link to post Share on other sites
electrathon Report post Posted February 11, 2014 The are many ways to hand stitch, the worst is the speedy stitcher. As everyone else has said, loose the stitcher and sew with two needles. Quote Share this post Link to post Share on other sites
Chief31794 Report post Posted February 11, 2014 (edited) Sorry but I've got to pile on, lift the stitcher lightly between your thumb and forefinger and release it over the trash can. Get an awl (learn to sharpen and strop it) or if that is something you don't want to pursue, the 2nd best option is a set of Diamond stitching punches and regardless of which then get some good harness needles, thread and away you go. Hand stitching isn't difficult to do, it is somewhat difficult to master, but practice is a good way to proceed. Chief Edited February 11, 2014 by Chief31794 Quote Share this post Link to post Share on other sites
Tree Reaper Report post Posted February 11, 2014 rawcustom; The problem with that is you are removing material by drilling which will weaken the leather. Try and use an awl when ever you can. Quote Share this post Link to post Share on other sites
BullFrog Report post Posted February 11, 2014 Thanks everybody. I suppose I should've looked here before buying the speedy stitcher. It's always good to find out that there is a better way. Quote Share this post Link to post Share on other sites
rawcustom Report post Posted February 13, 2014 Tree Reaper, I figured that view would come up. In my application of sewing a knife welt that is glued, stitched (and then I glue the stitching), I highly doubt there is a loss of strength in the joint. I also groove before stitching which again is removing material hence weaker, but will make my stitching last longer by shielding it from abrasive rubbing. Not disagreeing that an awl would be better, but depending on the application it may not be required. Quote Share this post Link to post Share on other sites
