Eaglestroker
Franziska Hatchet Cover
This is just a different project than what I'd normally do and was enjoyable for a change of speed. A repeat customer asked me if he could send in his Franziska to have a cover made. I said no problem and we set to work. His intended use was mainly as a protection thing while lashed to his pack. Ended up making a belt frog to match the belt ordered as well for a nice combination. Hopefully the customer has as much fun using it as I did making it!
Very nice Robert! that is a great color, did you dye it or is it drum dyed?
Best regards, Josh
Best regards, Josh
Josh, that particular piece is W&C drum brown. Feibings Dark Brown cut appx 30% dye 70 % alcohol will render a very similar color, but slightly more splotchy. I don't have a good picture of it but the pasted back side sure looks good when dyed.
