Members RoosterShooter Posted April 10, 2014 Members Report Posted April 10, 2014 I bought an old Singer 211G155 today from a yard sale, and the lady knew nothing about it. The machine was 'as is' and DID NOT come with a belt, but DOES have a servo motor installed on the table. The belt would be a 'V' style belt, but how do I measure for a new belt? Thanks Quote
Members Ken G Posted April 10, 2014 Members Report Posted April 10, 2014 You will probably be looking for a fractional horsepower belt. Measure the inner width of the pulleys near the outer edge. A 3L belt will measure 3/8" wide and a 4L will measure 1/2". The label on the belt will have a "0" after the length so a belt labeled "3L320" tells you it is 3/8" wide and 32" long at the outer edge. To measure the belt length set the adjustable pulley in the middle of its range and measure the circumference around the two pulleys. This should get you close. Now you just have to decide if you want to buy extra belts and return the one's that don't fit or buy them one at a time and make multiple trips to the hardware store. Quote
Members RoosterShooter Posted April 11, 2014 Author Members Report Posted April 11, 2014 I went to Rural King tonight and bought a couple of 1/2" belts. The won't fit on the machine or the motor pulley. I guess they're a 3/8" belt. One belt, a 1/2" x 4" was right on the length, but it didn't ride in the right place. I think a 3/8" would do it. Quote
Moderator Wizcrafts Posted April 11, 2014 Moderator Report Posted April 11, 2014 Almost all modern industrial sewing machine motor pulleys, the machine pulleys, as well as speed reducers, all use 3/8 inch wide v-belts, which are known as type 3L. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members SARK9 Posted April 11, 2014 Members Report Posted April 11, 2014 (edited) To get a starting point for your belt lengths, if equipped only with a pencil: Set your belt adjusters in the middle of the range of travel. Carefully measure the exact diameter of each pulley. For each pulley's diameter, calculate the circumference (3.1416 X diameter), then divide each circumference by 2. Now, carefully measure the center to center distance between the two pulleys: MULTIPLY that distance X 2. Calculation: (1/2 circumference A) + (1/2 circumference B + (center distance X 2) = belt length The length will *usually* fall within your adjustment range if you have measured accurately.... You CAN get 3L belts by 1/2" increments too. A 34-1/2" belt will be a 3L345 -DC Edited April 11, 2014 by SARK9 Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
