Members DavidL Posted April 26, 2014 Members Report Posted April 26, 2014 You don't have any contacts in the US that can order one for you and send it your way? I have contacts but I still find it ridiculous that I have to do that because they wanna rip me off. They say its because they can't send sharp items using USPS but i just received a knip knife from USPS. Quote
dirtclod Posted April 26, 2014 Report Posted April 26, 2014 Sewing last night through 2 pieces of 4oz leather and I had to apply a decent amount of pressure and it felt like a few times I might bend it. Puy the tip of finger along side the blade to support it when your punching your holes. Quote I'm old enough to know that i don't know everything.
Members oltoot Posted April 26, 2014 Members Report Posted April 26, 2014 The awl blade will have a widest point. It will be much closer to the back than to the tip. As long as this widest point is in the chuck, things are good. The length is necessary for tasks like sewing cantle bindings. The advice about holding your finger close to the point was good. Osborne makes some really short blades and even though they need a lot of polishing to be anything like the Douglas, maybe they would suit you better. Myself, over the years I decided that I needed several awls and so I have 6 in sizes (exposed not total length) ranging from about 3/4" to a big old collar awl that is close to 4" and pretty wide and thick. Most of them I use once or twice a year but then I'm real glad to have them. Quote
Members courtney Posted April 27, 2014 Members Report Posted April 27, 2014 I got a b.k. Handle and b.d. Slim awl a couple years ago and it fit perfect with only abut 3/4" sticking out. I just got a new Handel and it won't go down and sticks out too far with the one collet and the other one it goes down far enough but pulls out because the hole is not small enough and the collet is too long so I can't screw it down all the way to the handle. So... I stuck the awl in the other side of the collet that has an x instead of round hole And I ground the other side of the collet down on a bench grinder so it would allow the chuck to screwball the way down, now it's just fine! But, the old collets were better they would adjust down to zero the we ones only get so small. I actually called Barry King and he told me to to put it in the x side and grind the collet, he said if I messed it up he could send me a New collet, he was pretty nice , I'm sure he will try and help if what I said dos'nt work. Quote
Members Clintonville Leather Posted March 13, 2018 Members Report Posted March 13, 2018 On 4/25/2014 at 5:25 PM, DavidL said: Its hard to snap a solid piece of metal or bend it. I may have slightly bent a blade while rigorously sharpening it on a stone, so i know what you're concerned about. If your careful it shouldn't be a problem. If you can make it fit to the handle after you cut it then I don't see why not. How many mm wide is your blade? and which type is it(slim or regular)? Im experimenting with different size blades and I have an awl thats 56mm and its too large for 7spi. Also can anyone shed light on why bob douglas awl blades cost 30 dollars to ship to canada for such a small item. Realize this is an old post but I sell things to Canada. It is usually $14-20 to ship depending on location and weight. To add tracking is $12.95. It is just as expensive as shipping to the UK for some reason. Quote
