Anyone ever try "cultured marble" instead of granite..... I noticed places like Restore have fireplace surrounds made of that product.
I just bought an 15" x 12" piece from Springfield Leather for $18. I bought it and some other supplies to even out the shipping. it is a really nice piece. Although, the first piece I got arrived broken. Just called them up (talked to Emma) and she sent a replacement out right away with a UPS call tag for the broken one. Very pleased with the granite and very pleased with thier service!
Tom
I recently picked up a couple of sink cut-outs from my local countertop fabricator. He had a pile of them behind the shop.
I used polyurethane "PL" construction adhesive and glued them together, back to back. It is now 2 1/2" thick and solid... as a rock.
What I did too here and ended up getting a good square foot of dark polished tabletop marble, all for free. :)
I picked up four 3/8" thick pieces of flooring granite at Menards and glued them together with Gorilla Glue. Its solid in the center and heavy. Made the mistake of attempting to set a snap close to a corner and took a sizable chunk out of all 4 pieces. Its cheap, total cost was about $15 and the glue was about $10 of it. Its by no mean a permanent solution but works when your on a budget. My brother works construction so i'll have to ask him if he can pick up some scraps from countertops. He salvages tons of lumber from the dumpster for home projects/gifts. It saves the company on landfill costs so they are ok with it.
http://www.cgleathercraft.com
Member of the Iron Brigade.
For ~25 years a piece of cultured marble was all I had. I have kept it for an additional 25 yrs and skive on it. My tooling surface is a reject grave marker that I got from a monument place. 12x 24x 3" thick. inlet into a space on a stand that has a truck wheel base with a piece of 6" pipe to a table base of 4x18 C steel (think 1/2 of an H) to a 1" angle iron table frame the top being plywood 2ft x 3ft. 1/2 rubber belting between slab and steel
I used the free cast offs from a countertop place for a few years, until my brother in law bought out a closed machine shop and ended up with a bunch of granite surface plates that he let me grab a couple of. I built a work bench that the plate fits recessed into from some reclaimed 3x4 oak, so the whole thing cost me only some elbow grease.
(rdb):God looked down at the world, and said "See, right there in Witchita, next to the railroad tracks, I didn't put enough dandelions".
  • 1 month later...
