That's very helpful! I'm just not sure if that's my problem or not. It seems like the needle and hook will not meet up correctly. But I guess I should take some stuff apart to see if the bobbin assembly is full of junk.
I poked around a little on youtube and found this video for ya. If the guy is correct, the 267 in this video should be very similar to, if not identical to the 67 and 167, at least in the bobbin area ... That's what he said at the very end of the vid.
Between that, your German service manual, Google translate, sister-in-law, and here .. You'll get it working.
And we'll anxiously be waiting to see how creative you get with it!!
Bill
....but I guess I should take some stuff apart to see if the bobbin assembly is full of junk.
If you are not very familiar with your sewing machine, my I suggest you hold off until you have a better idea where the problem is. When my machine stops sewing correctly I stop and think about what was the last thing I adjusted or touch on the machine (i.e. changed thread, replaced needle, etc. That is where the problem lies. If the machine is new to you then go slowly and refrain from multiple changes. Don't ask me why I know this ;-) Good luck with your research...
Bob Stelmack
Bob Stelmack
Desert Leathercraft LLC
Former Editor of the, RawHide Gazette, for the Puget Sound Leather Artisans Co-Op,  25 years of doing it was enough...
Bill
My sister in law confirmed for me its the timing. The hook is literally 180 degrees off from where it should be. When the needle is at its lowest point the hook is on the opposite side from the needle.
btw...I don't see a video in your post.
Bob Stelmack
Right now I am just focused on why the hook won't take up the thread. If I fix that issue I think I'll be good to actually sew something. Or try to sew something!
OOPS. Right you are. Here's the link! http://www.youtube.com/watch?v=8pGCn0iw-50
Unfortunately it probably won't be as helpful as I hoped, but the guy does show how to re-assemble and lube the bobbin area which you will probably want to do along with the timing as well as now and then afterward. He does give us a clue, tho that timing is not set in that immediate area with this machine.
If you look at the link that dirtclod posted above, page 2, entry 2 by CowboyBob mentions a belt that can cause timing problems. That may give you a starting point and an idea what to look for in the service manual. Google translate might be helpful at that point.
Wish I could tell you more, but I don't know much more about sewing machines than you do, but I'm following a lot of the sewing machine threads so that when I do finally go that route, I'll have some info under my belt.
Hope that helps!
Bill
It also occurs to me that if timing is that far out, somebody may have disassembled things and not put it back correctly. That might be worth a check.
In the video it looks like the hook is positioned on the plate beneath by a rolled pin. That pin might be a shear pin to prevent excessive damage if something jams up, and could be broken. We used to use shear pins like that in some of the big laser printers, check sorters, and other equipment that I worked on in a former life. That might be worth a check too.
Hopefully some o' the pros will chip in on this and help you too if they're not worn out by Chinese machine questions.
I also just noticed your post from yesterday about the motor cap. Sometimes you can get by without one, but usually not. Read the markings on the capacitor it should give you the info that you need to get a replacement. It'll be marked with some voltage (VAC) and some capacitance, probably in the uf or mf range. A good source for motor caps is http://www.grainger.com/category/category/capacitors/motor-supplies/motors/ecatalog/N-9yp?redirect=capacitor
Hope that helps
Bill
So I got lucky! My father in-law is an aircraft assembler for GE. A co-worker of his rebuilds and services sewing machines as a hobby. Its a small world. He is going to come over and check things out for me. So now all I gotta do is wait.
As far as the capacitor...I ended up re-wiring most of the electric as it was old and ratty. So it should be good. "Should"
