Members Kevin Posted January 31, 2008 Members Report Posted January 31, 2008 But do any of these materials shrink and actually bind the wood together? The rawhide is not just there for a coating. I think if you want something new you will have to get rid of the wood and start with a totally blank slate, otherwise it just seems to be guilding the lilly. Some " English" saddles use nylon trees that are so dense you can drive a tack in and it will pop right back out. I've seen a lot of innovations over the years, some are good, but most just show why things have stayed pretty much the same for so long. That said, at least people are trying things and thinking. Kevin Quote
Members Hidemechanic Posted January 31, 2008 Author Members Report Posted January 31, 2008 (edited) JonW, welcome to the discusion.. Sounds like another related topic. There was a guy in Calif. doing carbon graphite trees but he quit before I could get one. Don't know anything about his recipe. I don't know if it matters if we get 50 or 100 posts on a thread, but I guess I'll go start a new one on fiberglass and see where it goes. GH Edited January 31, 2008 by Hidemechanic Quote You did What??
Members jonwatsabaugh Posted January 31, 2008 Members Report Posted January 31, 2008 I'm not sure what you mean by the wood being bound together by the shrinking rawhide. You can't compress the wood to make it more dense. If you need the rawhide to hold the wood together you have a very inadequate structure. As I mentioned earlier, carefull selection of materials is important, especialy the core being the wood. Many of the custom makers prefer yellow poplar (as I do) for the bars because of these excellent qualities 1) outstanding nail and screw holding abilities 2) clean straight grain 3) when dry it is very dimentionally stable 4) it is easy to machine. Take an old saddle apart that has a rawhide covered tree and you will find that the rawhide has little to no grip on the nails and screws. When removing them though I can tell you what kind of wood is beneath the rawhide, good or bad. Wood will be the material of choice for a long long time for a list of reasons to long to list. Remember, we are basicly precision slulptors. We need a material we can sculpt. Jon Quote
Members kseidel Posted January 31, 2008 Members Report Posted January 31, 2008 Jon, The wood structure of the tree is certainly criticall to a superior tree. However, The rawhide encases the wood in a "shrink to fit" housing. It is not only a protective covering, but increases the strength of the wood greatly. There is less flex in the rawhide than the wood preventing the wood from flexing to the breaking point. I believe the real strength of the tree is relative to the strength of the rawhide. I have never seen a tree broken that the rawhide did not fail first; either scored and separated, or lacing worn out allowing the hide to come loose. As long as the hide stays intact, it is nearly impossible to break a tree under reasonable circumstances. Same seems to hold true to fiberglass trees, only the fiberglass does not seem to take as much stress unless layered heavily. As you mention, wood is a sculptable material, and reasonably available. I think that if a tree were to be made out of another solid material such as plastics or resins or a muriad of other modern materials, and then covered with a good rawhide covering, that we would also have an acceptable tree of comperable strength to wood. Injection molding trees is not a new idea, but the only one to make it into production is the LaPorte tree. Using strong enough materials that were lightweight, and would hold nails, screws, and glue have been previously too costly for the industry. We cowboys that make up this industry are not chemists and chemists are not horsemen. A co-op effort might someday produce a modern tree that will replace the traditional wood tree. Cost is another factor. Not many saddlemakers would be willing to pay double or triple for a "new" contemporary tree when they can buy the traditional for less. We saddlemakers are unique individuals that like to customize our trees to a shape and fit that we think is best, and this sets us apart from our competitors. A molded tree cannot be changed. Yet another complication. Many of you readers are from other industries and may have ideas worth pursuing. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members Hidemechanic Posted January 31, 2008 Author Members Report Posted January 31, 2008 LaPorte is a new name to me as of late, but Ralide has been making injection molded trees for many years. Does LaPorte use a differnt compound than Ralide? I am behind the curve a bit in the last few years. I'd like to know more about LaPorte. As for the earlier injction molded trees, they were one that was advertized that you could run over them with a truck, but in my experience repairing them, they seem to get brittle with age. I've seen the bar ends shatter and seem especially to follow lines between nail and screw holes. I've also seen bars break and forks on endurence trees that have less material in that area. Just my thoughts on injction molded trees in the past.GH Quote You did What??
Members kseidel Posted January 31, 2008 Members Report Posted January 31, 2008 Laporte saddle trees are very different in compound than ralide. Much stronger and more rigid. They are available with a cable rigging molded into them. I don't have any experience building on them nor have I had occasion to repair one. Mark Howes from Double H Ranch saddle shop in Fort Collins CO developed the line and one of his sons is the mfgr. Ph # 970-482-6229. Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members D.A. Kabatoff Posted January 31, 2008 Members Report Posted January 31, 2008 Last summer I had a fellow call me to ask my opinion on La Porte trees and cable rigging. I told him straight up that I'm a traditionalist and would probably never use anything but a handmade rawhide covered wood tree. I have used trees from some of the finest treemakers around such as Rod and Denise from this forum, Rick Reed, Warren Wright, and Glenn Christman. When I first started making saddles I was using trees from Bowden, Superior, and Hercules and it wasn't until I saw a fine handmade tree that the differences in quality and fit became apparent. This fellow came out to visit me a few weeks later and brought a couple of La Porte trees to show me and perhaps change my perception about them a bit. I brought out a couple of nice handmade Wade trees so we could compare them side to side. Here is what I concluded... The material they are made from is infinitly better than the old Ralide trees that I had seen broken so often. The groundseat has an acceptable shape that was alot better than I thought it would be. Compared to the trees I am used to, the bars had substantially less surface area in both length and depth and for guys really using the saddles hard, that would be of concern to me. The trees are limited in the sense that I can't ask them to shave a corner off a cantle or make the fork thinner or fuller or move the widest point of a swell up or down... this is something very important to me. Something I found interesting was that the tree this fellow showed me had some serious sanding marks on the bottom side of the bars and when I asked about them he said he had taken a belt sander to the bars to do some micro fitting for one of his own horses. I'm not an advocate of fitting a single horse in that sense, but found it interesting that this could be done to the tree without compromising it's integrity. The only other thing about it was it had cable rigging which I am not a fan of. My overall conclusion about the tree was that there is definitly a place in the saddle world for them as a cost effective alternative. That said, I'd still never use one... good handmade trees fit horses well, are available in almost any shape or form, have longevity, and even though they may cost more and take longer to get they are what my customers want. Quote
Members jonwatsabaugh Posted January 31, 2008 Members Report Posted January 31, 2008 There may be a little misconception about the trees I build. The wooden framework is strictly a traditionally hand made, fully customizable tree built to your specs with a non-traditional outer reinforcement covering. I learned the basics from Kieth Gertch as did Rick Reed and Bill Bean. As for the wood fracturing and breaking apart within the rawhide I've seen this happen on several different occasions. As of late Luke Jones, a well known cutting and reining trainer in my area, brought a saddle into my shop to replace a broken tree. The fork, cantle, and both bars were all broke completely in half but the rawhide was completely in tact. Granted, this was a pretty bad wreck, but my point is that the wood frame was a totally inferior structure. I got to stick to my guns on the importance of each step in the saddle tree building process. All the custom makers I know of take great care in building a superior wood structure. By the way, my trees will sell for $465, not out of line for a handmade tree. Jon Quote
Members jwwright Posted January 31, 2008 Members Report Posted January 31, 2008 Jon, I have met Luke a couple of times, and competed with / against him at the World show. Good hand. I would like to visit with you about your trees. You can message me through this board with your contact info if you care to do so. Thanks. Quote www.jwwrightsaddlery.com
Members kseidel Posted February 1, 2008 Members Report Posted February 1, 2008 Jon, Keith Gertsch has made most of my trees for about 25 years. I would be interested to know more about the trees you are making. Send me a personal message with more info. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
