Members edd Posted August 28, 2014 Members Report Posted August 28, 2014 Hi All, Today I received a reconditioned Fortuna skiving machine having waited impatiently for a month for it to arrive. I'd asked for a V50 S or equivalent machine, but I'm not exactly sure what it is that I've received. I was expecting a bottom feed machine, with continuous drive motor for the bell knife and a separate clutch motor for the feed wheel, as I thought this was standard with the V50 S. On the machine that I've received, the bell knife and feed are both driven together, which really limits it's effectiveness. Is it possible to simply install a separate motor to isolate the knife from the feed stone? My knowledge of machines and motors is pretty pathetic so I'm trying to consume as much info as possible from the internet at the moment, I'd really appreciate any advice! Photos attached. Cheers Edd Quote
Contributing Member Ferg Posted August 29, 2014 Contributing Member Report Posted August 29, 2014 I don't have a Fortuna but have one very similar with both top and bottom feed. My machine feeds from one motor. Bell knife, feed for top and bottom are synchronized so you can vary the speed of feed while everything else responds to that speed. I would not want different speeds for each operation. ferg Quote
Members edd Posted August 29, 2014 Author Members Report Posted August 29, 2014 Hi Ferg, I read through some of your previous posts about skiving machines. They really helped me get a better understanding of some of the variations and things to look out for so thanks for sharing all your research! Good to know you use yours comfortably with the knife and feed roller synced. I'm still tweaking the various adjustments and trying different types of leather but it is certainly still very usable in it's current configuration. I just figured it'd be best to have the knife turning at a constant speed for optimum cutting and then to use the clutch to have more control when feeding through lightweight leather. Looks like it is possible on this machine as there are two separate pulleys. I'm just not sure yet about the most suitable single phase motor to use for the bell knife. Need to do some more homework! Quote
Members Andrew Chee Posted August 29, 2014 Members Report Posted August 29, 2014 (edited) I think that that's possible and probably relatively easy to do. There's the belt that goes from the motor to the machine. That pulley on the machine controls the knife. From that pulley there is another belt that goes to another pulley on the back of the machine. That pulley controls the feed wheel. Remove the belt between the two pulleys and rig up another motor to run that back pulley and now you have independent control over blade speed and feed speed. The easiest thing to do is to buy a cheap clutch motor and connect that to the knife pulley. You can rig it so the motor is constantly engaged from the moment you turn the power on. That way, you have a constant speed knife. Then you use your servo motor to control the back pulley so you have better feed speed control. Andrew Edited August 29, 2014 by Andrew Chee Quote
Members edd Posted August 30, 2014 Author Members Report Posted August 30, 2014 Thanks Andrew... That's confirmed what I was planning to do. Looking inside, it actually all looks very straightforward. Any idea what spec the motor should be? Something like this: 1500rpm/4pole, 0.75HP/550w ? Cheers! Quote
Contributing Member Ferg Posted August 30, 2014 Contributing Member Report Posted August 30, 2014 I can see where you are going with this. When I feed thin leather chrome mostly, I want the feed and the knife to turn slowly in comparison to other leathers. Easy to control. If the knife is as sharp as it should be there is no problem with the cut. I have simply gotten used to the way the machine is set up to begin with and have no problem with it. Different strokes for different folks! LOL ferg Quote
Members pcox Posted August 30, 2014 Members Report Posted August 30, 2014 I have mine setup with 1 motor. The knifes run full speed but the feed is controlled with the clutch. I used an old style clutch motor and added a pulley between the motor and clutch. Works great. Quote
Members edd Posted September 1, 2014 Author Members Report Posted September 1, 2014 I can see where you are going with this. When I feed thin leather chrome mostly, I want the feed and the knife to turn slowly in comparison to other leathers. Easy to control. If the knife is as sharp as it should be there is no problem with the cut. I have simply gotten used to the way the machine is set up to begin with and have no problem with it. Different strokes for different folks! LOL ferg Yep...if it works, it works Fitted a new knife but will have to wait for a deburring rod to arrive before i can get a decent honed edge on it. Obviously no point really trying to skive anything until the blade is razor sharp This manual someone posted a link to on the forums a while back has been a lot of help getting things adjusted http://aoi.ou.edu/images/Leather%20Skiver%20Model%2010A.pdf Quote
Members Andrew Chee Posted September 1, 2014 Members Report Posted September 1, 2014 Thanks Andrew... That's confirmed what I was planning to do. Looking inside, it actually all looks very straightforward. Any idea what spec the motor should be? Something like this: 1500rpm/4pole, 0.75HP/550w ? Cheers! For the fee I would think that any standard servo motor would do. There's not too much torque involved in feeding leather through and a servo will give you all the speed control you would need. Andrew Quote
Members edd Posted September 11, 2014 Author Members Report Posted September 11, 2014 I've bought an old Willcox & Gibbs 1/2HP 1425RPM motor for the knife. It weighs a ton. Not sure if i should have gone for a higher RPM? I've had some success after using the paper trick to adjust settings, changing the grinding stone and using the deburring rod to get the knife sharpened up. Managed to get some nice clean skives. Different story today though. The leather is struggling to feed properly so think I may need to change the feed wheel as it's not gripping the leather and feels a bit clogged up with dust. Its basically just burnishing the underside. The other concerning issue is there's some play in the knife from front to back. I can move it about a mm back and forth (see photo). I don't know if this movement occurs when the motor is engaged and the knife is spinning. Should i be worried about it? Advice to anyone in the UK thinking of buying a refurbished machine, I'd recommend going through Ernie at PMF-Fortuna. Even if it costs a little more, you'll know everything's been properly tuned up and you won't have to replace lots of parts . He was good enough to spend a bit of time giving me advice over the phone. Edd Quote
