johnggrg Report post Posted September 8, 2014 The picture shows the lid of the tool box I am making and wanted to know if someone had some ideas that might help me out. I need help. Not sure how I canattach them in lid so they are secure but easy to get out when needed. Any thoughts would be greatly appreciated. John Quote Share this post Link to post Share on other sites
mlapaglia Report post Posted September 8, 2014 use a spring clip to hold the handle at the thinnest part. They come in a lot of sizes. The one I posted a link to is just for ideas. Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 8, 2014 thats a good idea. if I can find the right size. thank you. Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 9, 2014 Anyone else have any ideas? John Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 9, 2014 mlapaglia at $8.60 each is kinda high for 1.and I would need 8 so that would really expensive. Was hoping to find a cheaper way. But if I could get those for ALOT cheaper then maybe. Anyone else feel free to add your ideas. Thank you all for the help. john Quote Share this post Link to post Share on other sites
WyomingSlick Report post Posted September 9, 2014 You need to pay closer attention It is $8,60 for 5 of them Quote Share this post Link to post Share on other sites
Sanch Report post Posted September 9, 2014 Just use a 1" wide leather scrap strap with some SS sheet metal screws between the tools to make some loops, kinda like a bandoleer/shotgun shell holder. Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 9, 2014 Your right did not notice that my mistake. The straps would work for the tools on the sides but not for the middle tools theyy have no room to move. john Quote Share this post Link to post Share on other sites
Sanch Report post Posted September 9, 2014 I beg to differ, turn them around so the handle is on the left Quote Share this post Link to post Share on other sites
WyomingSlick Report post Posted September 10, 2014 I should have mentioned that I don't like the idea of using clips like that in a toolbox that you carry around, one good bump, or drop, and they will fall out of the clips, Clips are fine on a tool wall, or in a stationary cabinet, but not in a toolbox Quote Share this post Link to post Share on other sites
JohnD Report post Posted September 10, 2014 Just to throw ideas at you, Velcro maybe? either velcro tape, part on the handle and part attached the lid or velcro straps attached to the lid and strap the tools in. Or line the lid with wool felt and wrap the tool handles with the hook part of the velcro, it may not be the most comfortable, but you can just toss the tools at the lid to put them away. Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 11, 2014 (edited) The tools are placed in the photo right were I want them to be. I do not want to move the middle ones at all. Thought about velcro but not really what I want in it. The clips are a good ides but as mentioned they could fall out and I don't want to use them for that reason. I like the idea of the leather strap for the 2 rows on the sides. But aa I said I want the 2 in the middle to be straight up and down as they are in the picture. But the strap won't work there. My other thought was to not put them in the box at all and fill the area with a carved leather peice with a border and something inside it. Not sure what but that was my alturnative idea for the lid. But thank you all for your ideas and keep them comming I have not decided yet still working on sanding it down. I should mention the box is made from 3/4 red oak. 19 1/2 long x 5 3/4 wide x 7 1/4 high. All solid brass hardware. I really don't plan on carrying the box around. Just going to sit on the work table unless I have to move it for one reason or another. The project started over a year ago with an idea. I cut the boards from a log I got from a buddy who had cut down an oak tree in his yard. He had kept the log to sit on around his fire pit. But I got him to give iit up and then dried it out useing the solar kilm method. Cut the boards, stack them, then wrap in plastic making sure to put holes in the bottom for water to drain. Dried to about 25% moisture. They started off being 1 inch thick boards then plained down to 3/4. Honestly nothing differant then store bought lumber just took longer to get and a little more work. I just wanted to make the box for my tools but then desided to make the lumber to build the box to. Alot of trouble I know but I don't mind waisting a little time. The removeable board that goes inside to hold the tools will hold: 260 tools 1 hefty handle 3 swivel knives 4 slots for extra swivel knife blades 9 differant diamond chisels 1 Vguage 3 oblong punches 2 copper rivet setters 4 differant sized spot setters and a place for the setting block 1 needle holder ( made from a hand stitching tool. It was the handle that has a screw off lid on the handle. I just tore off the stitcher part and kept the handle) I never used it anyway now I do. And there is still more room on the board for more that is just what I have laid out so far. Thought I would add that. john Edited September 11, 2014 by johnggrg Quote Share this post Link to post Share on other sites
billybopp Report post Posted September 11, 2014 Gotta love making something all the way from raw resource to completed item. Even if it looks the same as the wood that you might buy, YOU will always know the difference. Additionally, you know something more about how that wood got to the local lumberyard now. You might look at a bulldog clamp for the tools in the lid. They should grip a little tighter without loosening over time as the spring clip might. They're not expensive, and you should be able to find them at any home store for certain and probably wal mart or kmart as well. They are probably near the mops and brooms, as that is what they were really designed for. You might also poke around when you find them. There are a few variations on the design of these clips, so give 'em a look! http://www.amazon.com/Bulldog-Spring-Organizer-Brooms-Rakes/dp/B00GP59NBQ/ Hope that helps Bill Quote Share this post Link to post Share on other sites
mlapaglia Report post Posted September 11, 2014 Do leather straps and make the middle ones tighter and use a snap to lift the strap instead of sliding the tool out unsnap one end and lift out. Quote Share this post Link to post Share on other sites
johnggrg Report post Posted September 11, 2014 Hey Bill good idea I will look into those. Mlapaglia I did think of that does sound good. I also had a weird idea of adding shocks in it. So when you undo the lock the lid rises on it's own. Not that I need that but thought it would be cool. John Quote Share this post Link to post Share on other sites
bullmoosepaddles Report post Posted June 1, 2015 Search Neodymium Ring Magnets with CountersinkRare earth magnets are extremely strong and should hold your tools in place easily. They average about a buck or so each. If that is something you would consider. All you have to do is screw each magnet in place and lay your tool on it. Quote Share this post Link to post Share on other sites
