Hello All
Can anyone share a supplier who offers LARGE (around 17'') top frames for bags. there are many suppliers who offer purse frames, but i looking for much larger to be used in a "Doctor" style bag.
Thanks for any help
Chris
Ohio Travel Bag has a 16" and 18" option in their latest catalog. They will even make custom sizes for you assuming you need the minimum quantity they require which is 100 pieces. Hope this helps.
"Make every product better than its ever been done before. Make the parts you cannot see as well as the parts you can see. Use only the best materials, even for the most everyday items. Give the same attention to the smallest detail as you do to the largest. Design every item you make to last forever."
-Shaker Philosophy of Furniture Making
i made my own out of flat bar from home despot. it is very simple. i wanted to post a pic, but i don't know how to. anyway, the 20" tube on etsy is beautiful. if i had it to do over again, i'd probably buy it. i like the hinge. very clean looking.
upon closer scrutiny, i noticed that the aluminum tubes do not nest inside the other. they close up parallel to each other. if you look at the attorney's bag in the OP's thread, the top bars are nested. i'm not sure this would work out (or how it would look) on a doctor's bag.
Edited by ramrod
