I got a piece from a friend that just redid his counter tops. I also borrowed a diamond (dry) circular saw blade from another coworker to cut it with. Ii cut through as easy as cutting a piece of wood. Tape where you cut so that it won't chip and go slow. I used my router to cut a section out of my workbench to place it in so that it would be even with the bench top. I used silicon around the edges so there would be no gaps.
Art
I would like to resess my marble slab also, what is the support under the table. Thanks Darryl
When I was a kid I used to pray every night for a new bicycle.
Then I realised God doesn't work that way, so I stole
one and prayed for forgiveness.
Well my workbench is two old oak bank desks from the 50s. On top of that is 3/4" plywood and on top of that is 1/4" Masonite. I cut out down to the desk so the base it the desk top.
Art
Art Schwab
"You cannot teach a man anything. You can only help him discover it within himself." – Galileo Galilei
If you have a company that installs granite counter tops nearby, you can ask them for their scrap pieces. This will eliminate the cost of renting a saw from Home Depot. The dumpster outside of one of those places is usually loaded with great pieces of granite, large and small.
