post-55747-0-40808800-1412803342_thumb.jpost-55747-0-76160500-1412803356_thumb.j
Forgot to add a feature i thought was cool , to try to keep the cows brand scar on the bag so i incorporated it into the back.
Edited by the180fury
Oh yeah, that is cool. I have some of the same leather, and I made a journal with the brand on it. If you ever get around to burnishing the edges, it takes some work, but it does work okay with gum trag, and I think you'd be impressed with the improvement.
Awesome thanks for the tip !
looks excellent!
Just a man, a shop, and a long list of unfinished projects.....
My Website
My Etsy Shop
post-55747-0-56689600-1413078550_thumb.jpost-55747-0-18496700-1413078577_thumb.j
Finally completed the shoulder strap for my bag.......i thinks its done lol.
I ended up reinforcing the 2 inch wide strap through its full length with a 1 inch wide tie down webbing strap for no stretch and found a neat trick to punch the holes through and make them really neat. . Not sure if this is usually done or not but due to the webbing i cannot punch the buckle holes right through, so i punched either side and removed the little leather plugs then used a pointed tip soldering iron to shrink back and melt through on either side to create a perfect sealed hole. Worked really well if anyone has the same issues as i did.
Knowing myself i will be adding the odd little pouch here and there on the inside , even thinking of an external water bottle carrier ?
will have to design it in a way to look good though and match the design of the bag.
