Members tboyce Posted October 30, 2014 Members Report Posted October 30, 2014 Has anyone ever tried one of these? If so, what, in your experience, is it capable of?http://www.leatherpatcher.com/ Quote
Members Constabulary Posted October 30, 2014 Members Report Posted October 30, 2014 Member Darren Brosowski and / or Anne Bonnys Locker sells them. Here is another thread. http://leatherworker.net/forum/index.php?showtopic=50661 Quote
Members Darren Brosowski Posted November 3, 2014 Members Report Posted November 3, 2014 Has anyone ever tried one of these? If so, what, in your experience, is it capable of? http://www.leatherpatcher.com/ Properly set up the machine will sew 6mm of veg tan with #69 and 4-5mm with #138. The tripod is pretty useless so I make up a simple timber base. I also find the bobbin winder a bit iffy so I developed my own. Quote
Members tboyce Posted November 3, 2014 Author Members Report Posted November 3, 2014 Thank you for your reply. When you say 'properly set up' do you mean that the machine has been tweaked or are you referring to the selection of thread and needle size? Also, does the feeding mechanism mark up veg tan and, if so, is there a way to mitigate that?Thanks Quote
Members Darren Brosowski Posted November 16, 2014 Members Report Posted November 16, 2014 Thank you for your reply. When you say 'properly set up' do you mean that the machine has been tweaked or are you referring to the selection of thread and needle size? Also, does the feeding mechanism mark up veg tan and, if so, is there a way to mitigate that? Thanks Adjusting the needle bar to the correct height is the most basic tweak You need to grind the worst off the foot before coating it with rubber or it will cut your leather. Quote
