I use a calor gas heater in my workshop, until i get round to putting adiators in, runs on bottle butane gas...... gets really cosy, infact warmer thna the house, but has the tendancy to run out just when the suppliers are closed and its really cold outside....
as for electricity, depending on how much yyou need, ie, just lights or hand tools, as other have said above, generator-these can annoy neighbours big time if not careful being in london I guess there are a few around you.
other wise solar panels, i have them on my van and it powers everything, but most is 12v. you'll need the panel a distribution board, a mppt controller, and batteries to hold charge until needed. kits can be had for a couple of hundred pounds, although they will probably be around 100watts, should eb enough for lighting providing you have good light outside and not shadowed. but you wuld struggle for powering other things.
i have seen those portable starter charger units that hold big amounts of power, don't know how long the power would last for using for lights, but may be worth looking into as can be charged at home then used in workshop??
I use a Honda EU2000 generator for power in my shop for lighting and al heater in the winter, and in the summer I use (2) EU2000 if I use the air-conditioner. I would have bought the EU3000, but the EU2000's are easy for me to move around. My shop is a self contained camp trailer. It has everything I need workbench, storage, kitchen, refrigerator, bathroom, TV, etc. And, it keeps me from getting into the doghouse, as i'am already working in it. This setup is great, and will never change it. When the buddies come over for cool one, we head for the shop.
Howard
PS, I just bought conversion kits to run my generators on propane gas. Cheaper to use, as each generators hold 1 gal. of gas for about 8 hours running.
Thanks guys. We are having a very mild winter at the moment so I have not even had to worry about heating yet. In terms of lighting I am using a Dietz lantern and shall be getting a couple of Aladdins. Unfortunately paraffin does not work for me as I have used it twice in the last few days and catching even a whiff gets me all headachey and nauseous. I cannot stand cigarette smoke either. So I am going to have to use a clean burning fuel instead - olive oil?
I have my trust trangia set in there which I use for hot drinks and teas. I also have a large camping water carrier too. Whoop
Olive oil would not work, and it would also gum up the lamp
what sort of paraffin (kerosene) lamp are you using?
The hurricane lamp or any other lamp that uses a wick (like those you see in cowboy films!) will produce a smell. Those that burn paraffin vapour will produce less of a smell, but it's still there.
In the UK there was a well known paraffin vapour lamp, the Tilley, but they are long out of production, and are now collectors items
There is the Coleman lamp, but in the UK Coleman fuel is expensive
The best choice would be a gas lantern. I don't know what's on the market now, but I'm sure Camping Gaz or Calor will have something, or Surf The Net. The small lamps using disposable cartridges are fairly cheap to buy, but expensive to run in the long term. Those using a re-fillable cylinder are cheaper to run, and give a better performance, but you have to buy into the cylinder in the first place.
You could use a gas lamp for general lighting, with an LED headtorch for close up. not ideal, but do-able.
Try this website & forum; They are the experts with old & new camping stoves & lamps
http://www.spiritburner.com
If kerosene (paraffin) and white gas (coleman fuel) aren't good options for you, think about using propane. I don't know what's available over there, but there are camp lanterns here that are designed to run from small propane bottles, and they work great. The only problem is that those little bottles are relatively expensive. So, what I do when I'm on a long car-camp is to take a gas grill type propane tank, and adapter/distributor for lanterns, stoves and other stuff! It works great, and is considerably less expensive than the disposable bottles.
The key is the post, something like the following:
http://www.amazon.com/Stansport-Outlet-Propane-Distribution-Post/dp/B001DC5HAW/ref=sr_1_13?ie=UTF8&qid=1415635422&sr=8-13&keywords=propane+lantern
and add-on hoses:
http://www.amazon.com/Camco-59043-Propane-Extension-Hose/dp/B00192QBPQ/ref=pd_bxgy_sg_img_y
You just have to figure out some sort of stand for the hose-equipped lanterns. In my case, I feed stove / grill / heater so that's not a problem. It shouldn't be hard, tho.
You might also consider a reflector for your lantern to make better use of the light, as the situation demands. It's not helpful lighting the wall behind the lantern, nor the ceiling above.
Hope that helps
Bill
Just for the record, Tilley are still in business, but have no complete lamps on sale at the moment. www.tilleylamp.co.uk
When everyone is somebody, then no one's anybody
  • 2 months later...
Just an update. Still in the garage and it is not as bad as expected. However we are having a milder winter than normal so I have hardly had to use any of my heating at all. For anyone just starting out especially in the more expensive parts of the world *cough* London *cough* who needs space, rent a lock up garage. Check out the area first to make sure it is busy enough. The other garage owners are always around and we all sort of know each other now so I do not worry about theft. Get a site heater and gas bottle to connect to the heater. Get a few lanterns so there is enough light and boom ready to go. Thanks for the great advice all.
