This is a new wallet back plate with a celtic weave border. Regular size 2.75" x 3.25". Cheers!
post-2828-0-62232400-1415489503_thumb.jp
post-2828-0-92342500-1415489511_thumb.jp
"Out of my mind.....back in 5 minutes"
Nice. I like it!
Rohn
(John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV)
Very cool.
Chris
Just a man, a shop, and a long list of unfinished projects.....
My Website
My Etsy Shop
Looks good. May I ask what sort of press you use?
thank you. I test these with a 1 ton arbor press (which has a 1" square ram). I start in one corner, press them move over 1 inch. Rinse and repeat until it is done.
If I want to do it all at once, I've got a 12 ton shop press that can do the job.
I have found that if I put a piece of rubber or thick leather underneath the piece I'm going to press, it helps to push the leather up into the stamp for a good
deep embossing, especially on thin (4/5 oz) leather like used on a wallet back.
Cheers!
Can I ask how you made the back plate itself? Carved and then cast? Lost wax? Just carved out of the block of plastic?
I've done a bit of casting myself. It ain't as easy as you would think to get it perfect.
Nice work!
Thanks,
Michelle
Hello Michelle,
These are directly cut with a CNC router into 1/2" thick delrin.
These could probably be cast from these models, but it is just as easy to cut them individually now.
Cheers!
