Members Eddie1968 Posted November 15, 2014 Members Report Posted November 15, 2014 having issues with leather piece expanding when I do a lot of backgrounding. Which distorts the lines and edges already in place. I read some where about gluing poster board or something to back of piece to keep this from happening.....anyone use this method or have any other suggestions?? Thanks in advance. Eddie. Quote
Members Troy Burch Posted November 15, 2014 Members Report Posted November 15, 2014 If it's a big piece like a note book I glue it to poster board with rubber cement, that will solve your problem. If it's a strap like a belt I use packing tape. If you use tape rub it firmly with something to secure it better or the tape will loosen, I use a round maul. Quote
Members Eddie1968 Posted November 16, 2014 Author Members Report Posted November 16, 2014 (edited) Thanks i will give it a shot. it is a belt by the way. curious about removing posterboard......what kinda removal process does that take? Edited November 16, 2014 by Eddie1968 Quote
Members snubbyfan Posted November 16, 2014 Members Report Posted November 16, 2014 If it's a double layer belt like a gun belt, I'll go ahead and glue the two pieces together prior to tooling. Quote Keep on Chooglin'Check out my YouTube Channel, comment and subscribe for updateshttps://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
Members Troy Burch Posted November 16, 2014 Members Report Posted November 16, 2014 Thanks i will give it a shot. it is a belt by the way. curious about removing posterboard......what kinda removal process does that take? Use rubber glue, it's made for taking stuff back apart. Just pull the poster board off the leather (it removes easily) not the leather off the board, if you pull on the leather it could stretch a little. Quote
