I'm a new forum member and just getting back into leatherworking after about 10 years or so. I'm interested in making holsters because I don't like being limited to the generic holsters on the market. Some of them are pretty good but I have a lot invested in single action revolvers and want to give them the best care and protection I can. As a result, I'm in the process of designing a holster for a Ruger Single Six with a 6 1/2" barrel, and tentatively decided to go with something similar to what's in the Al Stohlman Holsters book on page 32 but without the tooling since I'm not that far along yet. I've always been paranoid of the blueing wearing off revolvers when using tight fitting commercial holsters so I thought about making a holster with a liner, but then after thinking about it more I decided to go with a full length filler, possibly with an end plug. Assuming I go this route, per the Al Stohlman book on page 12, the filler width should be 1/2", whereas on page 2 it says to cut your template 3/4" from the edges of the revolver. I believe you only extend the pattern 1/2" from the ends when using a filler since there won't be as much tension on the ends correct? Or, should you still cut the pattern 3/4" from the ends? I'm pretty sure it's just 1/2" when using a single filler since the width of the holster should decrease as the filler width increases (to a point). Any info would be greatly appreciated.
Thanks, Gene
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
I haven't read Al's books, so I can't comment on the directions listed there. When I line holsters, I match the liner to the shell for glue-up, full size. Just before stitching, I'll go in and skive the edge of the liner so that the edges line up well. If the pattern is utilizing a welt, I don't bother with the skiving. The shortening of the liner may be to allow for shortening as the holster folds.
Mike DeLoach
You might get away with 1/2" if your filler is the same thickness as the revolver.
5 leather patterns
Thanks for the info Twin Oaks and JS. I went ahead and cut the pattern with a 3/4" border and I'll cut the filler 1/2" per the book. I'll see how everything fits and I can always trim it back if it's too loose I'm figuring. Better to start with it too long than too short.
Gene
"...making a holster with a liner, but then after thinking about it more I decided to go with a full length filler." Serious question. What is a filler? Welt?
"You might get away with 1/2" if your filler is the same thickness as the revolver."
All of a sudden I am totally confused.
A filler is kinda like a welt for a holster.
I generally don't use fillers, I did on this holster because I thought it'd look good.
The customer wanted a pretty rig for wearing to barbecues. I thought a burnished filler'd add mass, look good and make the holster stiffer.
I just eyeball my fillers and welts, so I couldn't tell ya how wide it was but I think it came out kinda nice.
These two are for field use and neither have a filler.
They fit a 6" S&W L frame and a 5" Springfield 1911, I was able to get a proper fit without a filler and with a little wet molding.
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
Stopped using welts. PITA. Easier to cut leather to fit and wet mold.
Your holsters look very well done.
Gosh, your filler holster looks exceptionally good - outstanding job! That's what I hope to be able to do someday.
Gene
Oh....you meant a Welt. I thought you were asking about a liner. Carry on.
Mike DeLoach
I think what the OP is referring to as a "filler" is what I call a "welt". In my opinion, the primary purpose served by the welt is adding strength and rigidity to the seam of the holster. A secondary benefit is allowing a bit more space within the holster along the seam(s), which permits moving the stitch-lines closer to the handgun profile for improved fitting.
The welt will serve only a very limited purpose in reducing holster wear to the handgun finish. Holster wear is caused by abrasion. Unlined holsters with the flesh-side of the leather inside can produce more abrasion than a holster with lining of either smooth or soft leather, which reduces abrasion for better protection of the handgun finish.
In my experience, holster wear results from two things. First is drawing and holstering the handgun. Second is movement of the handgun within the holster during normal activities. So there are two approaches to reducing holster wear. First is a good close fit of the holster to the handgun, reducing or eliminating movement of the handgun within the holster. Second is a holster lining that reduces abrasion, both during normal movement and when the handgun is drawn and inserted.
Holster linings are usually done with either smooth or suede leather. Both will do the job, and both are in demand by people having strong preferences for one over the other. My personal preference has always been for a smooth leather holster lining because smooth leather does not tend to collect dust, grit, and debris over time like the open nap of suede leather will do (and some of that grit can be damaging to the handgun finish, embedded in the suede and abrading the finish again and again).
The soft leathers typically used in holster linings are invariably chrome-tanned (or other chemical tanning processes). This carries with it the issues of residual chemical salts remaining in the leather. These chemical salts can be very corrosive, capable of etching even stainless steels, and can certainly result in rusting of carbon steels (thus pretty much all handguns). Leather holsters and other leather products have a natural tendency to absorb and retain moisture (from the atmosphere, from precipitation, or from the user's perspiration). That moisture causes the residual chemical salts to go into solution, thus subjecting the handgun finish to a constant corrosive bath.
If using soft leathers for holster linings I recommend removing that the handgun never be stored in the holster, removing the handgun from the holster after each day's use, and wiping it down with an oily rag or silicone-treated cloth. Holsters should be stored separately in an area having air flow to allow residual moisture to evaporate away between uses (otherwise mold and mildew can become a problem).
Another approach to holster making provides the benefits of a holster lining while eliminating the issues of chemical salts. The holster body can be constructed of two layers of veg-tanned leather (no chemical salts) cemented flesh-side to flesh-side, and stitched at the edges. The holster will have a smooth interior and exterior. Depending on the application I use 5/6 oz. laminated to 4/5 oz., or 6/7 oz. laminated to 5/6 oz. Resulting holsters are exceedingly strong and rigid, form beautifully, and retain forming better than any single-layer holster of any weight.
This approach is not cheap (double the leather per holster) and takes considerably more time (cutting two pieces, cementing, stitching, edging, etc), but the results are very satisfying. I am attaching several photos of holsters made in this manner including a western style with welted seam and others with welts contoured to the handgun.
post-7487-0-88897400-1417445408_thumb.jp
post-7487-0-22023600-1417445468_thumb.jp
post-7487-0-68570300-1417445507_thumb.jp
post-7487-0-60488700-1417445529_thumb.jp
post-7487-0-82600600-1417445574_thumb.jp
Lobo Gun Leather
serious equipment for serious business, since 1972
www.lobogunleather.com
