Members charlescrawford Posted December 11, 2014 Members Report Posted December 11, 2014 I am looking for a revolver pattern. I have someone at our local gun club that has one of the newer Ruger revolvers. the barrel length is 3". I have tons of fold over patterns but they are wanting something that has belt slots. One on the left two on the right, similar to a pancake style slot arrangement. I don't have to worry about tooling but they want it small enough it won't go to far out the bottom of a vest. They also want something that can be formed in my thin air press like I do with my semi auto holsters. Anyone got anything even close to this? Quote
Members camano ridge Posted December 11, 2014 Members Report Posted December 11, 2014 (edited) Charles, are you refering to a Ruger LCRx 3" ? If you are making a holster for a revolver it will not be quite as flat as a semi auto. What you describe sounds pretty much like a pancake. The problem with trying to make it so it will hide under a vest, most vesta are shorter then jackets. That means that the holster would be extremely high ride. Therefore you will have a lot of the revolver riding above the the belt and it will want lean out, making it harder to conceal. I have a pattern for an SP 101 which would be close just needing stitch line adjustments. I will dig it up tomorrow and see if it will help you. Edited December 11, 2014 by camano ridge Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members charlescrawford Posted December 11, 2014 Author Members Report Posted December 11, 2014 Camano Ridge thanks! That would be awesome. Yes it is for a LCR x3. That's what I thought about the conceal-ability of the holster. I have never met these folks but I am suppose to see them sometime this weekend. Thanks again Quote
