I dunno bout that. Most of the servo motors I've had don't freewheel as well as clutch motors. My Family Sew barely has 3/8 inch of toe movement on the pedal before it engages forcefully. The only way to get more usable free motion is to remove the brake pad entirely. Most clutch motors can be set for well over 3/4 inch of free motion before engaging.
I mention this because I always hand wheeled my Union Lockstitch machines around corners, belt tips and fishtail patterns. Without the ability to freewheel, I would have had to depend on the ability of the motor to sew slowly enough to place the awl exactly where I wanted it, no questions asked. Also, without free motion, these motors fight your efforts to hand wheel a machine.
Edited by Wizcrafts
Posted IMHO, by Wiz
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
I was hoping to sew one stitch at a time around corners, also try 45 degree corner stitching. [ like pcox in the thread above , he has a servo on his randall ]. I contacted Campbell and they are just setting up a needle awl machine with a servo motor.. I am awaiting a video and reply from them.
Servo motors make 100% of thier torque at startup and ramp down as rpm increases. It should have no problem running your machine with the existing reduction. If you add a speed reducer, you should have time to go to the house for a tea between stitches. I have a Sew Quiet 5000 with 4/5 hp on a 153 w 103, and it will sew a stitch at a time with a 2" pulley and no speed reducer. Also very smooth on acceleration with no modifications needed. Gump.
No it is on a walking foot cyl. arm machine that will sew 3/8", and no speed reducer. Clutch motors are usually only 1/3 to1/2 hp., and because they are constant rpm, they use centrifugal force to maintain torque. Servo motors give better low rpm torque. Gump.
Here is my Randall with the servo motor. Said file was too big.
Edited by pcox
We have sold many servo motors to Needle and Awl owners with no problems mounting them.
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
