Members TomG Posted January 25, 2015 Members Report Posted January 25, 2015 I am making a new maul and decided to try making a leather handle like on my Tandy Stohlman maul. I glued up a bunch of 3" squares using contact cement and clamps and then mounted in my wood lathe. So.. I have a few questions for any of you who have done this. 1) Is leather harder on the tools than wood? I seem to be having to sharpen my roughing gouge frequently. 2) I do not have a chuck - only the spur and live centers that came with the lathe... How do I taper it down thin at the end of the handle. I have about a 2.5" cylinder now and can already see it flexing as I cut it. Thanks Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Tinkerton Posted January 26, 2015 Members Report Posted January 26, 2015 Did you put a core in it or is it just the straight leather? Quote
Members TomG Posted January 26, 2015 Author Members Report Posted January 26, 2015 No core. I thought about it, but haven't done lathe work in a long time and never on leather. I wasn't sure of what to use. Like I mentioned. With only a live center and a spur, all I could think of was a wooden dowel glued in, but then, I'd have to drill that out for the mounting bolt on the maul. What would you suggest? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Tinkerton Posted January 29, 2015 Members Report Posted January 29, 2015 I'll admit I know nothing about turning, but looking at a leather handled maul, it looks like there's most likely a metal rod that goes through the entirety of it. That would give it strength, rigidity, and mass. Quote
Members TomG Posted January 29, 2015 Author Members Report Posted January 29, 2015 Yup. There is always a metal rod or bolt that runs the length of it. The leather itself will never support the torque and flexion of a handle like that. I finally slowed down enough that I'm planning on heading the garage later to work on it. Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members oltoot Posted January 30, 2015 Members Report Posted January 30, 2015 I don't know if you could chuck up the finished maul but I have done it using a drill press and coarse sandpaper. I cut the stack to near finished dimension with a knife before finishing with sandpaper. To turn out a lot, I think that they are stacked up on a threaded rod, compressed to prevent slippage, then rough turned. They are finished when final assembled. It's a bit on the hard side to do just one and get by without all the creative solutions learned the hard way. Quote
Members BIGGUNDOCTOR Posted January 30, 2015 Members Report Posted January 30, 2015 They are turned with a rod inside. Doing it without one can be dangerous if it comes apart while turning. Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members TomG Posted January 31, 2015 Author Members Report Posted January 31, 2015 I had wondered about it before I started turning. But the square pieces got out of alignment when I glues and clamped, so I was afraid that I wouldn't be able to get a hole straight down the center. I should have made my squares a bit larger to allow waste during turning and done the center dowel. I'd still have the problem of attaching it to the lathe. I don't have a 3-jaw chuck and I'm not sure if the spur bit on the head spindle would hold a dowel of the size I want to use for the center bolt. But now that I have it turned down to a cylinder, I can probably square it up enough to drill a center hole straight and try the dowel. Fingers crossed... And I may just stick to wood <g> Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members BIGGUNDOCTOR Posted January 31, 2015 Members Report Posted January 31, 2015 Get a chuck, and a live center for the tailstock....life will be easier. Quote You laugh at me because I am different. I laugh at you because you are all the same.
Members oltoot Posted January 31, 2015 Members Report Posted January 31, 2015 The easy way is to punch holes in each piece of leather and stack them on the rod/dowel one at a time instead of trying to drill a hole through the center of the stack. Oh yeah, you would be surprised at how much compression you can squeeze out of wet pieces as you build the stack, then a fan to dry before the turning/smoothing. Quote
