rlpullman
Holster Gun Retention Hardware
I have seen several sites where they have holsters that have a type of retention adjusting screw. They look kind of like a Chicago screw with a rubber grommet. They are used to adjust the amount of retention on the hand gun. Does anyone here know of a supplier where I can get these?
Local hardware store- You'll need a t-nut, a bolt, a finish washer (aka 'cup washer'), and about 1/2" of rubber hose from the plumbing section.
Like Twin oaks said you can get pretty much everything you need at a hardware store or one of the big box stores. Below is a picture that shows pretty much every thing you need. If you don't want to collect everything you need you can get what you need from Rob Bennett the bluegunstore.com. Index fastners http://www.ifithermoplastics.com/category/fasteners also has everything you need.
post-15001-0-96530100-1425172072_thumb.j
Edited by camano ridge
Thanks you guys. That's too easy
I ordered all my hardware from here:
hasn't shown up yet, and I don't use hardware for retention but they had everything I wanted/needed and were way cheaper than the hardware store.
