Mark Peters
A Little Different Take On The Fob
I've carried a swiss-tech combination pliers/screwdriver on my key ring for quite a while. I've been wanting to try wet forming, and thought making a fob/sleeve would be good practice before working on a larger project.
If I was to do this again, I think I would incorporate the strap into the back piece rather than riveting on a separate piece. I also need to work on getting my rivets to set squarely, instead of sliding off to one side.
post-59915-0-86924500-1425442979_thumb.j
post-59915-0-59948600-1425442986_thumb.j
post-59915-0-79032700-1425442991_thumb.j
Edited by Mark Peters
Nice one! If your rivets are getting wonky could be they are too long for the leather. I usually nip the post down with diagonal cutters if that's the case.
anytime I've had to cut my rivet posts, I use my scratch awl to open the hole back up to as close to round as possible. The other option since you are already sewing, tack the strap with a bit of glue then continue your sewing right up around the top
post-44641-0-53296200-1426522439_thumb.j
What Halitech said or I just use the same cutters and lightly squeeze it back into shape.
