Will this machine sew veg tan leather up to about 1/4"?
My Consew 206 RB-1 will sew up to about 3/8" vegtan leather, but the 206 has compound feed. I don't believe the 205 does. I think the 205 was intended for fabric and garment weight leather. Hopefully someone on the forum will have experience with this machine and can tell you its capabilities.
Edited by Colt W Knight
The 205 has top and bottom feed, with teeth on the presser foot. It is primarily a vinyl and cloth sewing machine.
Posted IMHO, by Wiz
I understand it is not designed for it, but I've seen videos of it sewing some pretty thick leather, just seeing if anyone had experience doing that with it.
I worked for a friend in his leather shop and he had a similar machine. It pulled like a son of a bitch, but marked the leather pretty deeply. Other than that, it didn't match the capacity of the compound feed machine I had at home. Both were National brand machines.
I believe you will be better served by a regular compound feed machine, like the Consew 206RB-5.
Posted IMHO, by Wiz
Thanks Wiz, I have seen some smooth pressed feet for these as well, that's what I was thinking but I'll look around
205RB only has about 6mm foot lift by the hand lever so forget the bullshit from Jim Beaton about sewing 18mm. Less than 1/4" is all you will sew
