Hello,
I have been using solid brass rivets ( 2 part with washer kind) but the 12# and 9# are super hard to cut and peen and my wrist is suffering..
Can anyone tell me how reliable are solid brass cutlery rivets such as these http://www.leevalley.com/en/hardware/page.aspx?p=40386&cat=3,41306,41327
I know they wont be as tough as solid rivets but could they hold the straps on a back pack or bag? or are they not meant for that kind of strain.
Thank you!
Tb
Knife handle rivets are quite long and don't have a very large head. The shortest I could find are 3/8" and a cap dia. of 1/4". The 3/4-1" have a 5/16" cap. In knife use they wedge into the hole in the tang. In leather use it will only be a friction fit and could work loose.
Any chance " Chicago " screws would work for you? Just a thought. Good luck.
leatherart3.com
Thank you gump, it sounds cutlery rivets are a no then...
Chicago screws would work if I could find a way for them to be permanent... I have made a backpack with cutlery rivets and they would slowly unscrew and eventually fall out.
Maybe I could put some kind of glue in them before screwing in which case, yes that could work for me. I will do some research to see if a permanent chicago screws method has been discussed already.
thank you both
Loctite or similar bolt glues? Any hardware or auto parts stores near you should have something like this available. http://www.amazon.com/LOCTITE-37421-Heavy-Duty-Threadlocker/dp/B0028OJAIY
X2 on Loctite...............I use blue...............if you use red, it is pretty much assured you are never opening it again.
leatherart3.com
